Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
The octagon helps you to register the tools position and immediately sense any change (rotation). This gives you just a tiny bit more accuracy. It probably won't make any difference unless you're using a tool all day long or at least for extended periods. I prefer them on full size axes and pulaskis.
For those that make an octagon handle from a regular round handle, what method/tools would you use? Draw knife? Would a belt sander be too much?
Sure is, and that's what I do when I want to slim down a handle.While whittling down an overly thick handle last summer it dawned on me that copy lathes (which spin wood billets up against circular saw blades) are best suited to produce cylindrical or oval-shaped products. On the other hand an octagon is easier to make when using hand tools and provides a firm and very positive grip. Likely as not machine-made/store-bought handles quickly turned public sentiment (starting in the mid to late 1800s) into believing that oval shapes (along with curved profiles) are superior.
Most of us bitterly grumble about overly thick store-bought handles these days but 'octagon-izing' them (drawknife, spokeshave, rasp, belt sander) is by far the simplest/fastest method for slimming one of these down.
You got it!. In preparation for 'smoothing-out' the corners I suddenly realized I'd already achieved what I wanted (reduce the weight and slim down the handle) and the grip was fantastic. That's when I started wondering why standard (store-bought) handles were always oval.This is exactly how I arrived at a love of octagonal handles. You start thinning with lines you can easily visualize, which means profile from two angles. Then you take off the corners, then you realize that the handle is just right and making it any rounder is going backwards![]()
A woodworker other than a cabinet finisher or handrail carpenter would resort to 400 grit? That's a new one on me. 220 always struck me as standard fare for 'fine finish' guys and overly luxurious for others.For me its the stationary sander and just a plain old ferriers rasp/file (very coarse). Afterwards Filing the correct way removes a lot of material fast, filing the wrong way smoothens it out. After thats just sanding to about 400 grit.
