Ok, lets break these down for you...
- How can he ensure that his edge angles were identical with a bench stone and not a higher end guided system?
- He didn't say anything about the actual geometry of the knives.
He speaks of bevel angle as being a set and measured angle. How so?
He sharpened on a bench stone. No unaided human hand can set an angle and be repetitive enough to say "this is a 15° angle" across four knives of differing blade heights and thicknesses.
More on the blade thicknesses; He doesn't state a measurement of how thick BTE the knives are. This would have an effect how much wedging would be incurred by cutting through the medium. The harder it is to cut an object, the more force needed. The more force needed, the easier it is to damage the apex.
The height of the blades would also have an effect. The taller kitchen knife would want to track straighter due to the flats guiding the edge, where as the shorter blades would want to steer more, causing side loading and uneven apex wear and increase potential for damage from "dirty" cardboard.
Eta: Wouldn't this whole video actually be an arguement For Ankersons tests, since he cuts (basically) the same material, minus the board he is cutting upon?
Now for this part.
If Ankersons test only cuts into one material, made to a set standard, wouldn't this yield a more constant result?
In the video you linked, I understand that he is trying to account for a real world scenario, a chaos effect. But if you are trying to test an absolute, that should be mitigated as best as possible.
Which alloy holds an edge better, A or B?
Hrm, let me cut some potentially dirty cardboard with one and potentially clean cardboard with another. If this isn't controlled, this is entirely possible.
- This shouldn't happen. Yes, it will even out, but over what spread? One meter, 10, 50, 5 million?
Cut one material with comparable contaminants within each, not just guessing they are going to even out by the time you are done...
Mind you, this is barring the contact of the wood, which I do agree is detrimental to his results and Ankerson would likely get a more accurate reading if the wood contact was taken out of the test. This can easily be accomplished by milling out a notch that the blade can cleanly pass through.
A fresh board will yield a harsher contact surface for the knife edge but as the test progresses, it will become less of a factor (to a degee) since the board will degrade under the cutting edge. This offers a softer contact area for the knife edge.
This variable should be eliminated.
Is that clear enough for you
G
Gaston444
, or would you like me to spell it out further?
Just so you know, if you are quoting someone else, that means you are in agreement, (especially if you use it as a defense for your point) unless you state otherwise. So saying that they are someone else's quotes as a defense as to why you aren't wrong, is ridiculous.
You made a statement, now either stand by it or admit you are wrong.
