Why should I choose S90V ... instead of S30V? What are the advantages and disadvantages? How easy are they to sharpen compared to S30V?
Since the Chief has no liners, I love the CF scales. The next best thing to steel. Also noticeably lighter than G10 - for instance - to carry in my PJs . Plus S90V is my favorite SS. Sharpening on my ceramic stone is not very different from S30V. I stay at medium grit though (~800?), I like the bite.
rex 45 will probably be somewhere between s30v and s90v in edge retention but it is tougher than both. It is a non stainless steel so it will patina fairly easily.
If those three steels were all ~61 hrc your statement would be true. Spyderco s90v would likely be 61 hrc and the rex 45 would likely be 66 hrc. The Rex will actually smoke the s90v in edge retention. Also you could drop the edge angle lower on the Rex and further stomp the s90v.
Is the rex 45 66 hrc?
I've had trouble sharpening zdp 189, should I stay away from rex 45 then?
I only have experience with S30V and I'm comfortable with sharpening it.
Why should I choose S90V or rex 45 instead of S30V? What are the advantages and disadvantages? How easy are they to sharpen compared to S30V?
Yes (66hrc). It is very hard from the tests I have seen. Often harder than Spyderco ZDP; but don't be dissuaded.
What sharpening tech do you have access to?
DMT "stones".
Rex 45 sharpens fairly easily ,I think I read because of the smaller carbides you don't need diamonds to sharpen (although I use venev)
I go to 1500 on venev stones and 1 micron diamond spray on a strop.... rex 45 has a unique feel ... not bitey more like a straight razor.... it cuts you before you even realize it
