I didn't understand what you were asking. Can you explain a little more?I have two otherwise-identical knives - one of which's blade is S35VN and the other of which's blade is AUS 10A.
Both sharpened @17°.
What differences should I be looking for?
S35VN will hold a cutting edge quite a bit longer. And it appreciates being sharpened on a diamond stone. You can sharpen it with Aluminum oxide stones, but diamond gives you better results.I have two otherwise-identical knives - one of which's blade is S35VN and the other of which's blade is AUS 10A.
As said, sharpen S35VN with diamonds and AUS10 can be sharpened even with normal stones.I have two otherwise-identical knives - one of which's blade is S35VN and the other of which's blade is AUS 10A.
Yes. And whatever else besides edge retention.... corrosion resistance, sharpening difficulty, breakage, and so-forth.... you have two cold steel knives of the same model and you're asking what's the difference between the two steels when it comes to edge holding? Am I right?
No, although you need to compare costs to other knives and then see if it's worth it to you. The S35VN is going to be a more well rounded steel than AUS10A, so if you have two of the same model, the S35VN for the most part will be the superior option. AUS10A is tougher though.Yes. And whatever else besides edge retention.... corrosion resistance, sharpening difficulty, breakage, and so-forth.
The S35VN knife cost 3x more than the AUS10A, and I am wobdering if I threw some money away on the more expensive knife.
To add to this, if you already have both you can now have the cheaper one be a beater and the S35VN be preserved for fine cutting tasks or daily edc stuff.If one is three times more expensive than the other and they are the same model, you should definitely go with the cheaper one. It's always good to think like this: is this one knife better than three identical ones? Of course there are differences between these two steels. But as a daily user, the edge retention is the most noticeable difference and believe me, it's not that important (I'm talking about these two steels). In fact, I don't think you will observe enough of a difference to think it is important. You can buy two of the aus10 and use them by rotating them (So it holds edge longer![]()
)and buy a nice whetstone with the remaining money, and if you ask me, you can buy one of the aus10 and buy a whetstone with the remaining money and have a nice meal
. But since collecting is not a rational business, I can't help but echo bf's motto: buy both.
Not to nitpick, but AUS10 does develop some spotting during summer if you sweat a lot, which I experienced myself and there's plenty of evidence in FB Cold Steel group that I'm far from isolated casee.Heat treatment matters for how much difference you'll see in edge retention but S35VN should be better. S35VN is also a huge step up in corrosion resistance. While not as bad as D2, AUS-10 is weak enough on corrosion resistance that it will be an issue for more people in more situations than a lot of other budget steels that can offer similar edge retention.
That said, I feel like 154CM, N690, VG-10, and 10Cr15CoMov are just better choices. I'd also be happy to choose 14C28N or 9Cr18Mov with a good heat treatment over AUS-10.
Really thinking about it, what does AUS-10 bring to the table that other steels don't? What does it do better? I mean, it's AUS-8 with a little more carbon... I'd be okay if I never saw it used in another knife.
Not thrown away. You have 2 knives that have different jobs. S35vn is one of the most well-rounded knife steels out there. It's probably the easiest of the super steels to sharpen(imo).I would use the aus10a for edc and keep the S35vn for special occasions.Yes. And whatever else besides edge retention.... corrosion resistance, sharpening difficulty, breakage, and so-forth.
S35VN for special occasions?Not thrown away. You have 2 knives that have different jobs. S35vn is one of the most well-rounded knife steels out there. It's probably the easiest of the super steels to sharpen(imo).I would use the aus10a for edc and keep the S35vn for special occasions.
If you use the
I think bean counters Like to sit around and argue numbers on a spread sheet, in the real world, if you actually use the steel you'll get some actual data on matters of steel properties, even then--use more, discuss lessS35VN is a good everyday steel. Versus AUS-10, corrosion resistance is probably the clearest victory. Really, it just seems better across the board, subject to heat treatment of course.
Cost is the only downside. A knife costing three times as much in S35VN versus AUS-10 feels a little nuts but it will cost more. On the budget level, Kubey is probably the most prolific user of AUS-10 and a lot of those knives are around $50. That feels okay although what I said a few months ago still stands. I'd honestly prefer N690, VG-10, 154CM, or any of the other budget stainless being used at that level. Like Chinese D2, the edge retention isn't enough better that I care (or would even notice).
