I will throw a little twist .. quite literally. I use a Cast saddle stitch on a home made saddle pony. No stronger way to put pieces of leather together.
So lets say you pass your right hand needle through the hole first but you havent pulled it tight. You pass your left needle through the hole. Now you take the thread from your right needle which hasnt been pulled taut and cast it over the left needle. Now pull both ends tight. It basically creates a knot with each stitch inside the hole. I have done it so much I can do it while blindfolded.What is a cast saddle stitch?
Upsides .. you can cut half the stitches and still not pull the leather apart. The stitch looks the same on both sides of the material.
Downside is subjective. If you are using an awl and like a somewhat exaggerated zig zag stitch and I will admit .. sometimes I think it is very cool looking .. the cast stitch is a bit more reserved on the zig sag. Still a beautiful stitch just maybe not as dramatic as a standard saddle stitch.
Yes. What stitch is this called. I like how she says you may have to watch the video a few times to get it right. Like 10 or 20 times!Do you mean stitching like in this video?
To me it looks like putting in a basic over-hand knot that sits in the leather. Looks like a regular saddle stitch but won't pull out as easily if the thread breaks.
