Just weld it by hand. As you say, it is a very simple process.
Or, get that mill and roll all the san-mai you wish. Let us know how it works.
I have two powered mills and at least three hand crank mills that I could sell to the san-mai guys.
It s indeed simple process .Maybe two years ago I do that . 3.5mm 15n20 in middle and two 3mm 52100 from side . Perimeter weld , heated to welding temperature and in my vise....works on first try .It laying somewhere in my shop , it is about 4 inch long and about inch and half wide .....clean and temperature is two major factor for success..I don t waste my time hanging on bladeforum , you can learn are lot
Now , I have hydraulic press /50 T home made/ right outside of my shop , but is it hand operated ......and work only in one way..down .
I doubt that you talk from personal experience about this topic .....You should know that it is not easy to work on cold silver .In that video that small press is move silver easy .I don t think that to weld san mai i need that much pressure so i THINK that this jewelry press should work .I don t intend to make hundreds ...just one now another one maybe next summer , I do this for fun don t forget that .You say that the rollers will suck the heat out of the billet too fast ? How ? Did you try that so you know ? I don t think so ...sorry ! Contact between rollers and steel is very small at first and steel MOVE ......And because of that small contact surface pressure on steel is high ,depend on opening of rollers and dimension/thickness of steel which goes between them ....
Look , I have make roll press for my service more then 30 years ago , but it has three rollers because i use it for work on leaf springs ............
I like this idea of rolling mill because it is quiet , i live in very urban environment .
What i want to do is this ..................1.5 or 1.8 mm 1.2519 steel as core and 1mm stainless on sides .....to get something like this on picture ,clean line between steel and even/centered core thickness when you look in spine so that s why I think mill is right tool ?
I found another video......leaf spring
