- Nov 23, 2003
I am wondering what type of sanding blocks most of you are using to hand sand your blades? If you could post a photo, it would be most helpful.
I use a piece of Micarta with a very high (shore D hardness) piece of elastomer/urethane bonded to the flat side for sanding. The "hard" rubber allows for minor flatness imperfections, but very little.
I know all the techniques of cross sanding, making sure the previous grit is complete before proceeding onward, use of good wet sanding lubricant (I'm a recent convert to WD-40 thanks to a recent thread on this forum: I used to use simple green or windex), and the use of premium sanding papers.
I may slightly convert my methods to the Nick Wheeler method of using a steel sanding block prior to using the "padded" block for final sanding, but am always searching for ways to be more efficient.
Who's going to invent the mechanical blade sander with adjustable sanding pressure and automatic paper indexing movement after about 5 - 15 passes?
Here's a couple of photos to get the idea across.
Please note: these are unfinished knives, work in progress.
Mike L.
LoGiudice Custom Knives
Mike L.
