Sandpaper Grit size for Mirror Polish
Bearzilla911
Hello,
For sharpening knives using sandpaper on a rigid mousepad, what is the minimum grit size that will give a mirror polish and what grit size will give a visibly scratch-less mirror polish?
Thank you!
You’re probably going to be around the 2000 grit range. I usually start at 600 and work my way up to 4000, wet sanding. The type of steel may factor into this as well but I’m not sure.
Starting around ~ 800 or so --> hazy with hints of mirror, depending on the steel type.
Around ~ 1000 - 1200 - 1500 --> imperfect mirror with some still-visible scratches.
2000 or above --> mirror becomes much brighter and scratches are less obvious unless viewed under bright light and/or with magnification.
Some highly wear-resistant steels like D2, S30V, etc., will resist the high-mirror polishing using SiC wet/dry sandpaper alone, past ~1000-grit or so. With those, diamond compounds at 3-micron & finer will work much, much better (and much faster) when used on hard, smooth strops of wood (balsa, basswood, etc.).
Less wear-resistant steels will take a high polish easily with aluminum oxide-based polishing compounds like stick/crayon-type 'white rouge' (or grey). Some of those are aggressive enough as polishers, that sanding up through ~2000 may not be necessary. A dense loading of compound on something like hard-backed denim can be very aggressive at polishing right through coarser scratches, with steels like 420HC, 440A, etc.
If you have a buffer or grinder with buffing wheel, using that with polishing compound appears to be a big time saver ... based on videos I've seen on Youtube.
I have a dremel, maybe I can put some polishing compound on a tiny buffing wheel. I ordered sand paper up to 7,000 grit. Seems like that should be more than enough for a mirror polish.
