You're going to get a mirror finish using belts you're using for sharpening, especially loaded leather. You need to establish your own grind lines, then refine them for a "brushed" look satin. There are belts designed specifically for that.
+1 Pretty much.
JohnnyDarko said: "...when I use my belts the finish gets very shiny. I am thinking of getting some high grit and even a leather belt with compounds."
It "Sounds" like you already have a belt sander??????
If so, what size?
You say your current belts leave a shiny finish - yet you imply you don't have high grit belts (???) which seems to imply you have medium or coarse grit belts (????).
I think there is a possibility (????) that you are using your belts beyond their ability to "Cut".
I consider 220 - 320 as medium grit belts that still grind, profile and refine shape. If these belts leave a "shiny" finish, they are most likely worn out. Normally, 220 - 320 grit leaves a rough to semi smooth satin finish for me.
Of course all belts become less and less effective as they become worn out and their sharp grits become worn and less effective.
The following is somewhat subjective, but my best attempt to describe from my perspective:
40 - 80 as extra coarse grit = heavy steel removal
100 - 150 as coarse grit = slower more controled steel removal
400 - 600 as medium high grit = start to sharpen / semi polishing
800 - 1000 (black/green compounds) as high/fine grit = polishing
Fine compounds (white or finer) = mirror polishing
If medium or coarse grit belts are leaving you a shiny finish, I would guess those belts are most likely worn out.
Worn out grits don't cut very well and tend to to mostly just "Rub" creating friction that builds up HEAT more than they cut. You need to be aware of the dangers of heat with belt sanders.... and keep a "Dunk" near your grinding to cool the blades.... especially if using worn out belts.
I understand being frugal with belts and such, but at some point they just don't get it done anymore.
I have needed to be so cheap lately that I have even used the back side of worn belts to load compounds on - I don't have as many leather belts as I would prefer..... yet.
Sharpening with a belt sander is one thing - I personally highly recommend sharpening with belt sanders if some learning tips and curves are taken into account prior to going after a quality knife that you care about - ie.: do a bit of research and then do some practice on a few cheap pieces of junk steel.
I HIGHLY recommend a leather belt for sharpening. I actually recommend having 2-4 belts - 1 for each various compound as you shouldn't mix your compounds on a belt.
For me, green and white compounds offer the best bang for the buck.
Green does a LOT of polishing / gets blades quite sharp.
White gets edges shaving sharp, easily push cut paper and even closer to mirror finish
Both of the above are plenty for most real world needs.
But, if you want to do edge parlour tricks/split hairs and such, you can get grits down to fractions of a micron.
Satin finishing can be very easy with the right tools.
220 grit belts should visibly remove steel and leave a reasonably coarse cut/finish. 320 - 400 should still visibly cut, but they do start to smooth up the satin finish a bit.
So, you can get a nice satin finish with normal grinding belts, but I think there is a better option that is at least easier and more forgiving.
But, if you have INFI dimples and you are trying to get those out, that is a WHOLE different ball-game!
To remove INFI dimples, you have to "Grind" them out by removing a fair amount of steel. - Which is usuall easier done with 80 - 100 grit and then back down the line of finer grits to the finish you want.
You need to be reasonably proficient with the use of a belt sander or you will seriously risk doing damage to the grind lines and/or temper of the blade because to remove INFI dimples, you need to do a fair amount of grinding on the "Flats" of the blade. If you are not good with a belt sander, it is pretty easy to mess up the flats and/or the rest of the grinds.
If you have a knife that doesn't have INFI dimples OR you don't mind satin finishing over the INFI dimples which means you will see them, the EASIEST way I have seen to get a nice consistent satin finish is with
Scotch-Brite Belts on a belt sander.
The Scotch Brite belts I am familiar with include:
Charcoal = Medium grit = Rough satin / light to moderate steel removal - somewhere between 220 - 320 grit, but about 25% as agressive and more forgiving.
Blue = Fine Grit = Smooth satin / very minor steel removal - probably somewhere around 400 grit (???), but less agressive and more forgiving.
White = Very Fine = ??? I don't have and haven't used, but i assume very fine satin and very minor steel removal. - probably around 600 - 800 grit (???)
You can remove INFI dimples with medium Scotch-Brite belts, but it would take a lot of time and you would likely start to change the grind lines with Scotch-Brite belts same as regular belts. Scotch-brite belts can and do sand/remove steel. They just don't remove as fast as some of the coarser sanding belts and they are more forgiving for a more consistant "Satin" finish. But, they will also "Round-over" corners to some degree because they are somewhat "Self-Padded". They have a dense sponge like ability to compress - which contours around corners and therefore rounds them over.
I have an old 4" x 36" sander that I use. I like the larger surface area for certain things. Mine has a LARGE flat platen surface on one side and I have modified the back of mine mine to be able to flip it over and convex on the back.
The PRO knife-makers favor 2"x72" belt sanders. And I am sure I can appreciate why. But, I have not been able to afford... yet.
A 2" wide belt with most any length would be fine for most knife-making tasks including grinding and satin finishing as well.
While I like my 1" belt (OK) for sharpening and many other tasks (I am sure I would prefer a 2"), I don't know how well the Scotch-brite belts would work on a 1" wide belt for satin finishing most knives. (????) But, I imagine it could be done with reasonable results.
For satin finishing with Scotch-Brite belts, I think the wider surface area would provide more consistant results / more consistant "scratch" lines.
But, Scotch-Brite belts are not cheap. They typically seem to be on the high end of pricing for similar sized belts.
On the other hand, they seem to last a reasonable amount of time.
Good luck.
