RokJok
- Oct 6, 2000
Stanley model 15-333 folding construction saw
Length open: 13-1/4"
Length closed: 7 -7/8"
Standard blade length: 5" tip to front of clamp
Weight with blade: 6.5 ounces
Max width across handle: 1-1/8"
Max blade length to close: 8-3/4"
Max width closed (back of handle to blade lock button): 2"
Blades: Accepts standard jigsaw and reciprocating (recip) saw blades available at home centers, hardware stores, tool vendors, etc. Jigsaw and recip saw blades have varying tpi counts: coarser for cutting wood and finer for metal cutting. The standard Stanley blade that comes with the saw is 10.5 teeth-per-inch (tpi). I also used a Vermont American 6 tpi (5-1/4" cutting edge) and Skil original model "The Ugly" 5 tpi (8.5" cutting edge) recip saw blades. Gullet depth between the teeth varies on the Skil Ugly blade to help clear sawdust.Price: Stanley model 15-333 saw is about $10 w standard fine-toothed blade. Vermont American blade was $1.14 each at Home Depot. Skil Ugly recip blades are about $3 each in a 5-pack at Home Depot. FWIW, watch garage sales and flea markets for sawblades. I've gotten Lenox bi-metal recip saw blades (IMHO the best recip blades out there) 10-12" long for a few dollars per 5-pack.
Construction, Handle, & Ergonomics:
- Injection molded plastic handle is large & blocky for my small hands. I can stack both of my hands on the handle, albeit snugly.
- While the sides and top of the handle are flat, the edges are broadly radiused so the transitional corners don't cut into your hands.
- Molded-in grooves on handle offer decent purchase without being overly aggressive. They are properly oriented for a "cut on the pull stroke" type of saw.
- Handle's semi-pistol-grip shape is fairly comfortable
- Slot along spine of handle where the two halves meet has flashing ridge (from molding process) that is fairly noticable.
- Plastic locking button/slider
Closing & Locking Mechanism:
- Does not lock blade in closed position.
- Protruding screw made closing stiff until it wore a small groove in handle material near pivot. The groove does not endanger the integrity of handle or pivot.
- Some vertical lock wobble in the locked open position. There is also some blade play within the slot of the lock block.
Blade Changing:
- Need a screwdriver to change blade
- Very tiny pan-head phillips screw (#6 x 5/16" long x 24 thread) holding the blade on is not captive and would be insufferably easy to lose, especially with cold fingers or trembling hands. Definitely carry some spare screws.
- The fine threads on this screw are easier to cross-thread and strip out than coarse ones. On the positive side, the finer threads offer better grip by offering finer increments of pressure as the screw is tightened and less inclination for the screw to back out under pressure.
- The threaded clamping plate that the screw snugs up (to lock the blade in place in the machined holding block) is captive in the handle and won't fall out with the screw removed, which is a very good design idea.
Carrying Convenience:
- Although it's shorter than the Tashiro saw, the Stanley feels bulky due to it fatter overall diameter.
- For the ounce-counters in the crowd, it weighs about half as much as the Tashiro saw, which is a good feature.
Extra Pluses:
- Storage slot in handle for extra blades, maybe as many as three or four.
- Made in the USA if that's important to you.
Tashiro's Zeta Brand Pocket Saw
Length open: 18-3/4"
Length closed: 10-1/4"
Standard blade length: 8-3/4" tip to handle
Weight with blade: 14 ounces
Max width across handle: 7/8"
Max width closed (back of handle to lock flange): 2-1/4"
Blades: 11 tpi standard blade. Other blades that fit it range from about 9 tpi to 22 tpi. Zeta brand blades are available from www.tashirohardware.com, Rockler Woodworking catalog & stores, and some hardware stores (Hardwick & Sons in Seattle carries Zeta brand saws & blades). Rockler stocks the finer-toothed models for dried lumber vs the coarse-toothed ones for green wood. They didn't have the standard Pocket Saw 11 tpi blade at the Rockler store I visited, only about 14 tpi and higher tooth count blades.
Price: about $30 + shipping for folding handle & one blade from Tashiro Hardware. http://www.tashirohardware.com/
- Good fit & finish to the molded plastic and rubber handle materials.
- Ball detent rotating hub gives distinct 10-degree increments of rotation. I've found that the eccentric cam locking flipper will not lock the blade in-between the increments, because the cam does not have enough room to reach the "closed" position when the ball is riding on the plate between the holes.
- For my small hands, the diameter of the rubber handle section is quite comfortable.
- The handle is long enough for me to stack my hands on the handle (traditional double-handed ryoba saw technique)
- Very secure locking mechanism.
- Locking flipper has enough bearing surface to be relatively comfortable locking & unlocking the mechanism.
Blade Changing:
- No tools needed. The blades are friction-fitted into the rotating blade holder.
- Blade changing is pretty easily done. Tashiro recommends rapping the back of the blade out toward the tip to knock the blade out of the holder. However, I can remove & reinsert the blades by hand, although my hand tends to get chewed on a bit by the teeth when I do that.
- The closed length of about 10" coupled with the sleek handle, make this a very easy saw to stash in a day- or hydro-pack.
- Sleek rounded handle is easily pocketed while climbing up & down ladders or in the shop.
- The lanyard hole is about 3/4"x3/8" so it is big enough to easily hang on a nail or thread it with paracord.
Extra Pluses:
- Appears to be quite resistant to weather damage. Cliff Stamp inadvertantly left his outside through a snowfall and, when he came back to it in a few days, the light staining on the blade easily cleaned off with a Scotchbrite pad and there was apparently no damage to the closing mechanism.
World Multinational camping saw
Length overall: 17-1/4"
Blade length: 9-1/4" along the cutting edge
Weight without sheath: 8.25 ounces
Max width across handle: 1.25" at butt of handle, 1-1/16" across thumb-pad
Max width: 4.5" due to drop of the handle
Blades: 7 tpi
Price: IIRC about $9 with sheath in Walmart hunting/camping section
- Pistol-grip with pinky-hook shape of handle is both comfortable and secure.
- Rubber ridges on handle squish down for a bit more comfort.
- Flat thumb pad on top of handle provides very nice bearing surface for applying more downward torque to the blade when you want it to dig harder into the material being cut.
- N/A. This is a fixed-blade saw.
Blade Changing:
- Could be easily done with a #2 phillips or 1/4" flat-tip screwdriver, if you could find a blade whose mounting holes matched those of the handle
- At the saw's low price, changing blades is pretty much a wash. It's probably almost as cheap to just buy a new saw.
- Ambidextrous semi-swinger type sheath.
- Sheath has both belt slots and generously large nail-hanging hole
- While not made of bombproof weight plasitc, the sheath is sturdy enough for belt wear, as well as throwing in the toolbox, truckbed, car trunk, etc
Extra Pluses:
- Cheap enough to replace that you wouldn't worry about abusing or losing it
- Sheath has yellow plastic rollers to keep sawteeth from chewing at the lip of the sheath as the saw is inserted & extracted from the sheath.
Blade Changing:
Extra Pluses:
Blade Changing:
Extra Pluses:
Blades: 7 tpi
Blade Changing:
Extra Pluses:
