Scandi-ground blade and AUS-8A steel make the Cold Steel Finn Wolf a real steal (pun intended)
Despite my preference for fixed-blade knives, I do carry at least one pocket (folding) knife in addition to at least one fixed-blade knife. As with all tools, I have several that provide cross-over capabilities, so choosing what to carry often comes down to personal preference. So, when I received my first Cold Steel Finn Wolf pocket knife (the Olive Drab version), I fell in love with it and began to carry it exclusively.
The knife uses AUS-8A steel, a mid-grade stainless steel originally from Japan. It performs similarly to American 440 steel, with its ultimate capabilities determined by manufacturing factors such as heat treatment/hardness. Cold Steel and other mainstream knife companies make good use of the steel. In this case, Cold Steel built a quality knife with above-average performance at an absurdly low price.
Everything about the knife screams quality, from the fit and finish to the ability to easily swap the pocket clip for left or right carry, the durability, and its impressive Scandi grind. It makes sense since the design was a collaboration between Andrew Demko (Demko Knives) and Cold Steel President Lynn C. Thompson based on the Finnish Puukko knife. The edge geometry first attracted me to the knife - I love Morakniv blades - and this knife offered similar attributes in foldable form. And, like every Cold Steel knife I've received, it arrived hair-shaving sharp!
Given its solid construction, the knife is surprisingly light. Weighing 3.4 oz., it has a 4.375" Griv-Ex handle, a 3.5" long, 3mm thick blade, and a sharp, spark-capable 90-degree spine. The Tri-Ad lock is secure, albeit someone fidgety to unlock with one hand. That said, it's not likely to pop loose while using, so it's extremely useful for tough-use tasks.
The knife is functional at home and in the field. I tested throwing sparks off my Ferro rod, and it worked perfectly. I was able to split smaller pieces of wood using the "L" method. I wouldn't try processing larger pieces, but it made handy work of some 2" thick logs.
The Scandi edge is also excellent for basic utility tasks - cutting cordage (paracord and jute), nylon webbing, and slicing through thick rubber. It was also handy for food prep, although less so for slicing tomatoes (personal experience). Cutting meat and chopping vegetables: perfect.
When I found that Cold Steel offered the knife in multiple colors, combined with the quality-to-cost comparison, I decided to add them to my collection. At under $30 each (even less if you can find them on sale - I paid $20 each), these are a steal (pun intended)! I hope they release even more colors—I'll definitely grab them!
I like the Finn Wolf and have several. I love the basic design and find the handle especially comfortable in the hand.
>But I am annoyed with the placement of the thumb stud. You can't sharpen the scandi without removing the stud. So you are sort of forced to have a dual angle primary so that you can have a sharpenable edge. Then remove the studs and sharpen the scandi bevel on an as needed basis. The other option is just to remove the studs, but this produces a knife which requires two hands to open. Still not what I want.
> I also wish it had steel liners to reinforce the handle. A field knife is going to get tweaked and have side forces acting on it. I don't quite trust the straight plastic to hold in that situation.
Mine are not used "hard." Around the house, general utility use. AT $20, I don't have unrealistic expectations. How do you sharpen your knives?
This. I can't understand why they couldn't go with thumb hole like in the Tuff Lite.
I've been tempted to try these several times though.
I had a green one that I parted with a few years ago. Then found that I missed it. So I bought this red one, which I love. And I found that an aftermarket deep-carry pocket clip meant for an Ontario Rat-II bolted right on like it was meant for it. Makes it a little nicer to carry:
On my green one, I removed the thumb stud and never missed it. Probably do that with this one too. I agree: A Spydie hole would be awesome!
Need me a red one for the collection!!!
