P2P
- Jul 24, 2010
LolMy trunklid only closes halfway and since your post i decided to treat it like a downforce applying rear spoiler. It works, i kinda feel relieved
Border shipping times aren’t bad right now. I move a lot of product across for my work and it’s running pretty smoothly right now. I hope CRK gets down to the source of the problem with you knife. Good luck!My knife will be going back to CRK for assessment when the postal service doesnt take 3 months to get it there.
Enough is enough.
Thank you!OK... so I fiddled some more. Including a more vigorous table test (note: I've now caught up on the many many many pages of this thread and saw your video).
I can now see that it does flex a teeny weeny bit with quite a bit of force leaning on it with two fingers. There was no hint of failure and it flexes straight back - it doesn't jiggle or anything. There is no side to side flex at all.
I was curious and had a Spydiechef to hand and tried that out as well - it turns out it does the same thing (very very tiny movement as well) and I have used that with no issues for ages.
Anyway it doesn't bother me at all - it's hard to describe exactly but there is nothing loose while doing it and it doesn't leave anything wobbling about afterwards. The video in the thread showing the breakdown of various models helped explain why it is likely doing this - and could even be expected with the interplay of the three points of the triangle, their different hardness and shapes. Weirdly it felt kind of reassuring that it gave a tiny bit to avoid "popping" like one of your 21s did! Yikes.
All said and done I can't see this ever being an issue for me using the knife and wouldn't dream of sending it in.
I have been considering getting either an Umnumzaan or Inkosi - reading some of the comments on this thread gave me cause for pause but now I feel confident again. Note: I wouldn't feel great if I had side to side play or could move it with clicks etc just using my fingers - but I saw none of that on mine.
Hope this helps.
I had mentioned the direction of lockbar flex in a previous post. Here's a vid where you can see it.
31 PJ
As you can see in this particular vid, no failure.
Edit:
Guess I could have done my other 21's. Whoops.
21 PJ
21 Micarta
21 CF
As you can see they all flex upwards & no failure. Now, I'll go wipe my brow & check my pants.
31 PJ
Edit:
21 PJ
21 Micarta
21 CF
BD_01 ...no side-to-side flex or motion either towards or away from deeper lock engagement. I did not dare put any more force on the blade so there is no testing beyond what is on the videos. To anyone who asks "what if you put more force on the blade than what the videos show?" obviously this was not tested & no answers are had at the moment. Now I'm off to get more Sebie thumb. 31 is finally breaking in nicely.
Bravo and thanks for this.I had mentioned the direction of lockbar flex in a previous post. Here's a vid where you can see it.
31 PJ
Edit:
21 PJ
21 Micarta
21 CF
31 PJ
Edit:
21 PJ
21 Micarta
21 CF
None of my striders have any of this this movement at all. But again, it doesnt bother me that my sebs have it. I dont use my knives in that direction.I just checked this on an m.strider sng and it does not flex at all. But that’s because the lbs prevents it from going that way. Maybe that’s the solution, but I doubt they would do that. On the zaan the lbs doesn’t function that way.
It's a fairly basic function of geometry which indicates such a lock bar design will do this. The direction the blade tang pushes on the lock is mostly upwards, not into the lock bar. This isn't a function of the lock interface so much as the overall layout of the lock, and I have had a bunch of knives designed similarly which do the same thing (some Hinderers do this as well to a smaller degree).I had mentioned the direction of lockbar flex in a previous post. Here's a vid where you can see it.
31 PJ
Edit:
21 PJ
21 Micarta
21 CF
Did this on my 21 with a bit more force and lock failed. Its not something my other knives do so it's not okay. Was a sad day for me when this happened.
The most interesting thing to me, as far as this discussion goes at this point, is no longer the reported 31 lock flex, which doesn’t seem like something that would bother me, personally, but ultimate lock strength in terms of the lock failing and allowing the lock to slip, and the blade fold. CRK has stated somewhere (Tim Reeve on Bookface?) that the 31 lock is stronger. I don’t participate in FB so I don’t know. I can imagine how this might be true, if the 31 lock engagement point is allowed to pivot on the fulcrum of the ceramic ball, without being forced outwards by geometry.Did this on my 21 with a bit more force and lock failed. Come to think of it, it's a fairly basic function of geometry...
If you design a knife where the end of a lockface doesn't engage perpendicular with the end of your lockbar, its just going to happen.
Do you really think this next picture extreme in my book example is not going to fail?...
Just don't think much thought was given in this regard. Not much complaining maybe. It's all good to you good folks so. Its not something my other knives do so it's not okay. Was a sad day for me when this happened.
