So here is what i see...I will be talking about this gap here that Ive circled in the photo.
Framelocks are strong because they have three points of contact, the stop pin, the pivot, and the lockface. The reason that framelocks work is because the whole face does not contact the blade...just a single point. So when pushing the blade spine on the 21, it takes up the microscopic “gap” in the lockbar to full lockbar flat on blade flat contact.
On the 31, instead of shortening the lockbar length, to add the ceramic ball, they shortened the blade. This ceramic ball now protrudes out from the end of the lockbar 1mm to 2mm changing the shape of our “lockup triangle.” It also creates one point of contact but leaves a larger “gap” between the nonexistent flat area of the lockbar. See this photo...
So now, when you put pressure on the spine of the 31, there is no “flat” area to contact the blade, and you get serious flex which allows the blade to come off the stop pin, even more so than the 21. This troubles me.
Just to be clear...this is the direction of lockbar flex shown here...it flexes left, and springs back to right.
Now i do also have an inkosi here...the lockbar is thicker, and it does not have noticable flex.
However, the placement of the ceramic ball is different. As shown here...
On my particular 31 the ceramic ball should be closer to the blade edge(when knife is open) of the lockbar. So moved to the right of the arrow in the above picture like the inkosi.
This would negate a lot of the flex. As it would be opening up our triangle.
For me, the jury is still out regarding lock failure. Im hoping not to find out during use, and im not willing to push my new “expensive” 31 to failure in a test. Haha.
I just always relate “bank vault” lockup to the CRK sebenza...and this is anything but that. I think that disappoints me more than anything.
Since Chris was pushed out, they have managed to mess up the first 100 or so Impinda’s, and now have a non “bank vault” Sebenza 31.
Honestly, if it was any other company, and I wasnt so curious to how the 31 will hold up, I woulda returned it and posted a very unhappy post.
It is different than “lockrock” that is for sure. Because lockrock is when the lockbar wont fully engage leaving gap between the “point” and the blade tang, or when the “point” contacts the tang but slips outward easily, creating audible clicks when wiggling the blade up and down. The sound is from the blade hitting the lockbar and then hitting the stop pin.
Lockflex is when the “point” of the lockbar (the ceramic ball in this case) never leaves the blade tang (always has contact), but flexes with lockbar. The lockflex rock on the 31 is so severe that the blade comes away from the stop pin. That is what worries me.
If I have any of my lock geometry fundamentals wrong, and someone with experience building framelocks can correct me. I am open to that.
