- Jan 25, 2020
The overall size and specs remain the same between the 21 and the 31 models. Differences are:
. offset clip. i.e., more accurate lock arm tension, & cants more toward seam of your pocket,
. ceramic ball interface (harder than titanium) for the integral (frame) lock arm against the blade tang
. hardened stop pin via heat treating (more wear resistant)
. the handle design has been streamlined for slightly better ergonomics
. tighter tolerances (e.g., improved relief cut) . Removed the machining hole on the show side of the handle and as a result, inlays can now be a single solid piece.
But imho, you lose a little grip without the 2 piece inlays
. flared out chamfer and finger groove on lock arm
