An older thread revived, just in time
as this one is now in the G2 household.
Untitled by
GaryWGraley, on Flickr
Untitled by
and as mentioned, the lack of a 'kick' as most US made ones have the French are more into stream line approach and so you can get the problem of the blade striking the back spring if you happen to let it shut under it's own power. This one was no exception, as the tip area would get a flat spot from that, even if closed slowly. SO, I took my dremel with a hefty cut off blade and ground down a channel along the end of the back spring and now there should be adequate clearance, but I still close the blade by hand, slowly. The French folders I have owned, mostly by the family Chambriard out of Thier's France, have what I call a reverse kick, a bump up along the inside of the back spring, so that in effect should help keep the blades edge from striking the back spring. But the powerful force of the spring closing the blade often can defeat that small bump and you get a flat spot on your edge. So go slow when closing, and don't let others close it for you!
Also this past week I had this pretty folder in for an edge tune up;
Untitled by
Untitled by
Untitled by
And there is a NEW mid lock folder by Chambriard that I want to get, only two things stand in my way, one...money (always seems like an issue
) second, my normal US source for Chambriard folders is closing shop and I am not sure about how to go about ordering from overseas, in fact that does concern me to even try to do that, so I will have to wait until someone gets one and grows tired and decides to sell it and hopefully I can be at the ready to get it and have funds at the same time, a perfect storm kinda thing
So I doubt that will happen in my lifetime
Here's a nice review of that new Chambriard folder;
G2
