- Mar 22, 2006
have a 12 inch ontario (pretty dull out of the box) any pointers???
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
What type of file would you suggest buying?
For use in the bush a small mill file is sufficient for a machete. The edge will get all bashed up and a filed edge is sharp enough for most work.
If you want to get fancy and spend some time you can get a frighteningly sharp edge on any machete. I have recently been experimenting with various grades of sandpaper. I clamp the machete down to the workbench with the edge facing outwards.
I use the file to correct any dings or nicks in the edge and carry the grind all the way to the tip. I will usually file until I get a slight burr but sometimes I'll remove the machete from the bench and finish the edge on a EZ-lap diamond stone before proceeding to the final polish.
Note: Don't be afraid to take a file to a machete. I ressurect worn blades all the time by clamping them edge up in a vice and filing the edge right down until they disappear. Then just file away until the edge comes back and the machete will look like new, ready to get all new dings on the next trip.
I then wrap the file with a fold of 220 and sand off the file marks and burr. Repeat with 320, 400, and 600. It doesn't take all that much time and the result is truly impressive.
I like a nice durable convex edge up front at the sweet spot of the machete and at the base of the blade the edge resembles a scandi grind like a Mora. That way the edge will hold up to chopping where you chop with it and will shave like a knife where you have the most control.
On the spine I will square off the back of the blade for the first four inches. When the blade is scraped against a dry piece of wood it will produce handfulls of fine curly shavings for firelighting and the edge will spark a ferro rod very well.
The forward part of the spine I round off so it won't tear up my hand when scraping or using the blade like a draw knife or mess up a baton if I'm pounding against it.
That's what I do, anyway. I have a 12 inch Ontario set up like this strapped to my pack right now. Mac
Use a nice sharp 8-inch bastard file (with a handle on it). If you want the edge any more refined than that, use the file first and then give it a few strokes with one of those carbide chip V sharpeners. Good grief, you're not going to peel apples or shave with the thing!![]()
