Will a 1200 grit fine stone be good?To just find your angle using the sharpie you should use a fine stone. It'll remove the sharpie without removing much steel, allowing you to determine the angle.
Yea that should be fine for the intended purpose.once you find your angle you can go to the lower grits to actually sharpen it.Will a 1200 grit fine stone be good?
Ok thanks.Yea that should be fine for the intended purpose.once you find your angle you can go to the lower grits to actually sharpen it.
