SVTFreak
- Mar 8, 2011
Hello y’all. Let me start by saying I have looked at a dizzying number of threads and videos. My head is spinning. So many terms and makers and such. That said, I’m going to break down what I will have abs ask what I need.
I am not a professional chef. Simply home cooking. I do the family cooking. Love to cook. I am upgrading my knives through the next couple months. I have decided on Yaxell Mon chefs knives in a few different patterns. They are 3 layer vg10 advertised at 61 hrc. I also have a larger custom made chefs knife coming Monday that is W2 steel and measured at 60 hrc.
That said, I need help selecting how I will sharpen these new knives. I am no stranger to hand sharpening, having grown up doing it in Arkansas oil stones, and am not against it. I could use some practice and will get that on my old ones before touching the new ones. On my carry knives, usually set the desired bevel on a gatco diamond system (like a lansky). Then I touch up on sharpmaker. Not sure that info matters here. Basically, if I need to do some serious reprofiling, I would probably do it the same way, unless there is a reason to not. Beyond that, I like ease of maintenance. Anywhere I could use, say for instance, DMT diamond plates that require no maintenance, that would be great. Can I use those as course, then switch to water stones for finishing? Should I go with water stones or would the shapton glass work for longer without having to flatten them? What grits do I need? I don’t mind spending a little, but rather not break the bank.
If you, more knowledgeable and experienced people, where in my position with those steels, what stones would you use, and why? I’m trying to save myself a long and expensive learning curve here.
Side question, generally, how long does a water stone last considering use and lapping flat over time? How often does it need lapping?
Thanks a bunch in advance.
Pic for amusement. The custom knife that should be here Monday.
