- Jun 4, 2010
Every ACE stone I've bought has said "Made in USA" on the package
Hi,When I went to the ACE site and looked up these stones it is described as a 60/80 grit. Which is a mystery to me.? I'll concede the coarse side
could be 80 grit. But the fine side is near 200 grit. The two grits are not close. Looking on Norton's site their medium grit is 180 so, it is possible a typo occurred on the ACE site. DM
When I went to the ACE site and looked up these stones it is described as a 60/80 grit. Which is a mystery to me? I'll concede the coarse side could be 80 grit. But the fine side is near 200 grit. The two grits are not close. Looking on Norton's site their medium grit is 180 so, it is possible a typo occurred on the ACE site. DM
SiC is friable?
David Martin, thanks for your post. Informative and interesting. I had to go lower than 100-120 grit to get the reprofiling speed I want. Patience in removing relatively large amounts of knife metal freehand is not one of my strong points. But, after that metal is removed, a good quality coarse/fine stone, such as the one you describe, is what I'm looking for for sharpening and maintaining the edge.
I look for stones that are the most efficient, and can do what I need done for all my knives (I like utility, toothy edges), so I don't accumulate more stones than I need, and to keep the cost down. I'll definitely look for the Ace Hardware stone. Hopefully it's carried in all their stores. Thank you for your recommendation!
QEP makes a 60/80 grit "rubbing stone" for smoothing tile edges. I would have posted a link but still don't understand Bladeforum's policies about links.
That depends. Green is friable and black is not. Like many abrasives you can get it in varying degrees of toughness.Hi,
SiC is friable?
HH, I just checked the wording from the packaging on my 6" SiC stones and both say, made in China.? Does this have anything to do with it? DM
SiC IS friable. The particles themselves break down, Try lapping with it and you'll see. SiC, Whether in abrasive form or as a tool insert, is fragile. It'll break if you stress it the wrong way. I find that SiC stones give a wonderful finish compared to their grit level because of this.Hi,
SiC is friable?
The ace hardware website didnt used to list grits , a review mentioned making calls to find out its 60 80,
More weak evidence, the descriptions are very similar
Best for hand sharpening blades and cutting tools. Combination grits-coarse (60) for initial shaping and deburring-fine (80) for final honing of sharp edges. Fast cutting silicon carbide grain. Use with honing oil for best results.
- Size: 8" x 2" x 1"
- Grain: silicon carbide
- Grit: 80 grit-coarse removal
- Combination grits-coarse (60) for initial shaping and deburring-fine (80) for final honing of sharp edges
- Fast cutting silicon carbide grain
- Use with honing oil for best results
- Made in USA.
This is my YT channel, lately I've been putting up a lot more fitness stuff,
I can't PM you, but I thought you might watch this.
