Just picked up a triangular medium grit lansky dogbone ceramic rod to sharpen serrations.
Do you guys do each serration individually, or do you draw the knife across the rod in one motion?
The Veff tool is really a nice item and fills the bill nicely for most serrations.
Thanks for the info on the Veff ToolThat is an extremely interesting looking sharpening tool to say the least. I'm always looking for better and more efficient methods of making my Spyderedged folders sharper. I'm definitely going to get one of these soon. The only knock I've got against it as I do many other sharpening tools is that it's only available in one grit selection from what I can tell.
But with that aside I'm still going to get one because I see how it would enhance a guy's set of sharpening tools![]()
I've got one COLD Steel serrated blade from back in the Carbon V era and frankly I don't know how you would sharpen it![]()
I'm curious... what if someone could make a zero ground serration, i.e. the entire width of a sabre primary grind, you guys think it would be durable and easy to sharpen? I had this though the other day =)
Probably easier to sharpen (thinner is always easier). But, I'd worry about the points of the serrations folding too easily, or breaking off, depending on hardness. I've always sort of assumed the asymmetric grind of serrations, with a secondary bevel on one side (effectively widening the apex angle), was, in part, intended to make the 'points' a little broader and more durable. I guess it'd come down to how wide the primary grind angle is.
Every time I've tried to thin the edges of serrations a little too much, the points have usually suffered for it, as they get ground so fine as to make them too fragile and prone to folding or bending over. And in that instance, the upkeep and resharpening really isn't easier anymore, if the points are in constant need of straightening or reshaping.
David
I used to own one of these:
IIRC the packaging claimed you could just sharpen the serrated portion on a flat stone along with the rest of the edge. It worked OK but the serrations weren't as effective as the traditional arrangement.
