Me too. Don't know what for though. Damn addiction.Bought this stone at a "Dollar" store.
It was in "hardware"Have only seen it at one store.
It seems as if some stores that used to carry these are switching to similar stones in silicon carbide (SiC) abrasive instead; that's likely a better stone anyway. I've noticed this in stones found at Home Depot; they carry Norton's 'Economy Knife & Tool' stone, which used to be in aluminum oxide until Norton switched it to SiC around ~2008 or so, and also at Sears, where I saw one of the SiC versions recently (& they still show an AlOx version online).
I HAVE recently seen these at Harbor Freight, as well as in a restaurant supply store's cutlery section, both in the last month or so. As I mentioned earlier, ACE still carries the AlOx stones as well (in addition to several sizes of SiC stones).
David
Nice grab!
I'm not a huge fan of my Ace stone. I can't really tell if it's AlOx or SiC. I do like the "economy" SiC stone from Home Depot though. Only thing is that the coarse side is pretty smooth.
Hope you don't mind me asking a question?
How do you dress a SiC stone when the coarse side gets too smooth (swarf buildup)? I clean it with Bar Keepers Friend, but that does nothing to rough it up.
Nice grab!
David and Martin, thanks for your thoughts. I use the stone with usp mineral oil. The slightly thick stuff.
It was some time ago, but remember when we were emailing with Saint Gobain about the country origin of their stones, Mexico or Brazil (if I remember correctly)? For whatever reason I came to the conclusion that my stone was SiC. It's certainly black and doesn't look much like the AlOx Ace stone.
Maybe it's just me because my 120 grit Edge Pro stone seems very smooth. Don't know if you remember, but I had some trouble with it because I was using oil. The stone separated from the aluminum blank. I spoke with the EP CS and they said to only use water. The stone was appropriately aggressive, but has smoothed out quite a bit. One thing I've noticed is that there is a bit of rust on the surface which would obviously indicate swarf from my carbon knives. I found it interesting because I wouldn't have seen it if I'd been able to use oil.
So to lap a SiC stone, you need to use something more coarse, right? I think I may just try sand on the sidewalk, but grab some SiC powder if that doesn't cut it.
