Got my Edge Pro Apex. Still do most of my sharpening freehand but I wanted a better guided tool for jobs where, for whatever reason, I want faster results, want to create a more consistent bevel, or struggle to get certain blades sharp (I seem to struggle esp sharpening the belly area of very large fixed blades). I've used Sharpmaker in this role for years, but increasingly I've found Sharpmaker has limitations and can't handle some things I want to do. One example is when I want to quickly reprofile an edge to a lower angle say 10 or 12 DPS: the Sharpmaker can't do that, the Apex makes fairly quick work of it.
I got the Apex from Gritomatic with the 2 included Alox stones (220, 400), and a small set of his Venev diamond stones. Last couple nights I just experimented with a couple cheap knives, and watched a few vids as well as reading the docs. Definitely good to do all that before you sharpen anything that matters.
Tonight I did an actual sharpening job with a low-risk knife: one of our beater Victorinox paring knives. These have soft steel but are great cheap slicers--this one also had a really dinged up blade. I followed the suggestion in their docs and sharpened as follows:
* Profile a secondary edge of 10 dps > 220 Alox
* Cut a new primary bevel 15 dps > 400 Alox
* Cut a micro est. 18 dps > Spyderco fine ceramic
This took 10 minutes of sharpening, plus 5 total minutes of setup/teardown. The knife cuts like a laser passing all my usual practical sharpness tests, including push-cutting thin receipt paper at 45 degree angle. (no I'm sure it's not 'hair whittling' and all that, I don't care
). Could I get this results freehand, with my Arctic Fox stone + a ceramic, in 15 minutes? I don't know, I don't think so, even on this soft steel when you factor in a full reprofile. Also I think I'll get faster with EP as I get more effective with it.
So bottom line: first real sharpening with it went great, seems like it'll work for the uses I need. When I start sharpening my super-steel folders with the Venevs, I'll do another post.
