- Feb 24, 2014
Thanks mate, done.
Agreed.Labels easily get misused as a description, I'd prefer if the labels were absolutely honest
cigarette paper Cross slice-start-push-cut:
cigarette paper Longitudinal slice-start-push-cut:
because slice to start then push cut the rest of the way is much easier than a push cut with no slice from the start
That assumes the knife is 90 degree to the paper (perpendicular) in all 3 axes
Speaking of papers, it would be useful to include paper thicknesses,
~0.0040 inch is ~100 microns average a4 printer/copy paper
~0.0020 inch is ~50 microns for phonebook or yellow pages paper
~0.0010 inch is ~25 microns for Tops cigarette rolling paper
~0.0005 inch is ~12 microns for OCB Hemp cigarette rolling paper
ref Re: Practical Ways to Evaluate Sharpeness
The Sharpness Chart has got final edits.
Thanks everyone for feedback, I've cleared a few things to myself.
The Chart is ready for this forum sticky, if the forum admin cares.
Agreed. posters did: what did the person use to measure thickness.
My Mitutoya dial indicator, thickness gage, (range 0.01-5 mm) doesn't have the resolution to measure microns under 100µ. All I can tell is that my cigarette paper is <0.01 mm (and probably > 0.005 mm) . Same problem with the handheld micrometer. (The person doing the measuring in the "practical ways to evaluate sharpness" link used a micrometer. He didn't say what kind or if he was rounding up or down to get so many significant figures.)
So, I don't know how they are getting that many significant figures. I'm not saying it can't be done, just that I don't see it mentioned. Maybe I missed it?
Does anyone have exact measurements of the cigarette papers? Measured with equipment with the necessary resolution/precision?
That sharpness chart got me excited about putting as fine an edge on my blades as possible. I thought after getting my Ontario Rat1 to shave that i had hit the peak, now I know better.Not exactly so.
Personally, I do not own any data; the manufacturer Edge-On-Up is the source of information for us.
The edge sharpness tester inventor Mike Brubacher had carried out a study together with the Arizona State University SEM lab, and established the relationship between his instruments reading and edge apex width. Understandably, the raw research data will hardly ever become available online.
We distribute his instruments in Australia and New Zealand, and follow the manufacturer statement, as in the Sharpness Chart.
In this thread I give references to other sources available in the public domain chiefly for those new to BESS, as cross-referencing supposedly is convincing.
Another reason is that my own BSometer is always set at low threshold - for anything to pass it, it must be real and confirmed by independent sources.
Let me repeat myself, approximation is inherent to any method other than taking every edge under the SEM.
Yet to my knowledge, BESS is the only available for home use that provides us with this.
We should not take BESS scores as a conclusive data of the edge apex radius, however to a first approximation, as an idea +/- it's fine.
Most industrial users use them on a relative measurement basis, but the standard BESS scale makes possible the data comparison and exchange.
All the doubt in the world cannot alter fact - it works.
BESS edge sharpness testers reveal the unseen that eludes sharpeners' comprehension. And the sharpeners who've harnessed it have the best protocols.
Where it seems inappropriate to older generation, it is meant to be entertaining...
As to the quality - shot and edited by my 11-year son on his iPad.
FYI, we've added a sharpness chart to the Sharpening Resources section of our website
http://knifegrinders.com.au/Manuals/Sharpness_Chart.pdf
Includes data for all traditional sharpness tests.
C cutler81
For two reasons: first, BESS is young, the BESS edge sharpness tester was first patented in 2014, and became available in the end of 2015;
second - its primary consumers are industrial, they don't post on forums - there are publications on BESS in specialist magazines, but those are distributed by subscription.
The factory ships it everywhere, please check the manufacturer's website for contacts - I can't go into details here as this is not a sales thread.
With the most demanding tests, the edge oxidation effects the result. Immediately before those tests the edge should be stropped on clean smooth leather or clean linen to restore its original sharpness.
Chromium in stainless steel reacts with the oxygen in the air to form a passive complex chrome-oxide surface layer that prevents further oxygen from rusting the surface.
This film thickness originally is 3-5 nm, but can reach 20 nm on mechanically polished surface, i.e. worsen sharpness score by 5 to 20 BESS.
5 to 20 nm added to the apex radius, multiply by 2 in terms of thickness, i.e. 0.01 to 0.04 micron of added edge apex thickness.
Practically it means that the most challenging sharpness tests like the top HHT, that you can perform immediately after sharpening you can not an hour later. Oxidation can easily change your sharper than razor edge to just safety razor sharp if not duller, which is not enough for the most challenging tests.
Finally I've got a full assortment of Rizla cigarette rolling papers.
From the Rizla website: "The variation of thicknesses determines how long the paper burns for, Red papers are the thickest so burn the fastest while Silver are thinner and burn the slowest."
Smokers know that pleasure from a cigarette partly depends on how fast it burns.
I've got Rizla Silver - the thinnest, then goes Blue, Green, Orange, and Red is thickest.
Tested them for cross push-cut with the same blades I used to test Tally-Ho rolling paper:
Wilkinson Sword DE safety razor - scores 30 BESS on the PT50 edge sharpness tester, has 0.05-0.06 micron edge apex width; and
a knife that scores 20-25 BESS, i.e. about 0.04 micron edge apex width.
With the Tally-Ho rolling paper, the Wilkinson Sword razor almost passes the test, but the cut is somewhat rough; the knife passes cleanly.
Silver - Wilkinson Sword razor - clean push-cut
Blue - Wilkinson Sword razor - clean push-cut
Green - Wilkinson Sword razor - clean push-cut
Orange - Wilkinson Sword razor - roughens the paper
Red - Wilkinson Sword razor - tears the paper
Silver - Knife - clean push-cut
Blue - Knife - clean push-cut
Green - Knife - clean push-cut
Orange - Knife - clean push-cut
Red - Knife - roughens the paper
The most resemblance with the Tally-Ho rolling paper has Rizla Green.
Results contradict our intuitive expectation that a thinner paper would be harder to cut.
I've updated the chart on our website
