zyhano
- Dec 3, 2009
So, i'm whittling hair, shaving it off my arm against the grain, have it pop off from my arm, slicing through paper, push cutting through newspaper, and I' m wondering where I am with my sharpening...
Can it get sharper and how can I tell..
Also I find the names confusing. Juranitch defines shaving sharp and razorsharp but here on the forum you can also find scary sharp and tree topping sharp and loads of other terms. It confuses me and it's hard to compare things when you do not have the same words for same things.
I hope to have it all cleared up for everybody so we can have an inventory here for common sharpness levels from dull to sharp, how to get there and how you can tell it is so.
Can someone please define sharpness levels in the following way:
name
How to achieve it normally
How you can tell
I'll start
0. Abused. Use your knife in ways it was not made for - Your edge is chipped and nicked, rolled over, planes of metal from either side of the knife do not come together.
1. Dull. Use your knife a lot and don't sharpen it - Knife won't cut very well, force is needed to make the knife cut or slice, tendency to crush soft material when trying to slice.
2. shaving sharp. Sharpen the knife on an appropiate abrasive and get the planes of metal from both sides together to form an edge. Shaving sharp can be reached up from XC dmt stone or 220 grit japanes waterstones and up - Knife shaves hair from arm, rough cutting feel to it when slicing tomatoes.
3. <your turn guys>
Please feel free to add or insert levels and to alter or expand on how to get ther and how you can tell.
When/if there is a consensus and the info is valuable, i can edit the first post here to just get that info in this post
Enjoy and I hope we can get somewhere here..
name
How you can tell
I'll start
3. <your turn guys>
