Like Dan - said either find old cutlery, etc made from it or make it yourself - first you make blister-steel:
from Knight's 1881 Mechanical Dictionary
http://www.princetonimaging.com/library/mechanical-dictionary/subjects/idx_metallurgy.html
Blister-steel. Steel formed by roasting bar- iron in contact with carbon in a cementing furnace. It is so called from its blistered appearance. To improve the quality, it is subjected to two subsequent processes, which convert it into shear-steel and cast- steel.
Shear-steel. Blister-steel, heated, rolled, and tilted to inmprove the quality. Several bars are welded together and drawn out. Shear-steel is named from its applicability to the manufacture of cutting instruments, shears, knives, scythes, etc. The bar is sometimes cut, fagoted, reheated, and again tilted. This may be repeated. The terms single shear and double shear indicate the extent to which the process is carried.
Cast-steel. Blister steel which has been broken up, fused in a crucible, cast into ingots, and rolled. The blocks of steel are melted in crucibles of re fractory clay, and the molten metal is poured into ingot-molds of cast-iron. These are opened, to let out the red-hot ingot, which is then passed to the rolls. See CRUCIBLE; INGOT-MOLD. The process of making cast-steel was invented by Benjamin Huntsman, of Attercliff, near Sheffield, England, in 1770.
Some more info:
Very briefly, the cementation process involves placing alternating layers of iron bars and charcoal into refractory chests, which are subsequently sealed, or cemented, closed. This prevents the charcoal from igniting. The chests sit in a large furnace, which is then fired for a period of a week to ten days. The firing is monitored to maintain a temperature below the melting point of the iron bars, while carbon from the charcoal diffuses into the iron bars. These bars tend to have a blistered, or scaled, appearance when they emerge from the process - hence the term, blister steel.
The process of producing shear steel from blister steel was introduced into England by Wilhelm (or William) Bertram, of Germany, who was apparently shipwrecked on the North Durham coast in 1693. Before long, he was involved in steel making in Newcastle. Bertram's stamp was that of a pair of crossed shear blades, which came to be associated with the product/process he pioneered. Interestingly, this process doesn't seem to have been introduced into Sheffield until about 1767.
Again, very briefly, shear steel is produced by cutting selected bars of blister steel into shorter lengths (ca. 18"), fastening them into bundles using wire, then hot forging them (presumably through the use of tilt hammers) into an ingot. This results in some hammer refining and a flexible steel particularly well suited for certain kinds of cutlery work.
Shear Steel - Before the development of Crucible Steel, Blister Steel was forged by repeated folding and forge welding to mix the areas of high and low carbon steel. Shear Steel was the lowest quality generally created and further folding and welding created Double Shear Steel. Long regarded as ideal for blades and cutting edges, primarily because the slag trapped within the steel lead to a serrated edge without it being purposely formed. Until the mid-18th century, the quality of steel was unreliable. Steel was made by heating iron bars, covered with charcoal, for up to a week. The end product was called 'blister steel'. Blister steel was then turned into 'shear steel' by wrapping blister steel bars into a bundle and re-reheating them before forging the bundle. The heat and action of the forge hammer welded the bundles together to the required size. Although this steel was used to make razors, files, knives and swords, the process was extremely laborious and no more than 200 tons a year were produced in Sheffield in this way. Benjamin Huntsman's invention of the crucible steel process changed all of that. He was the first person to cast steel bars, producing tougher, high-quality steel in large quantities. In 1846, the French metallurgist Monsieur le Play wrote of Huntsman: 'His memorable discovery advanced the steel manufactures of Sheffield to the first rank, and powerfully contributed to the establishment of the industrial and commercial supremacy of Great Britain.' Within 100 years, Sheffield was producing 40% of total European steel production at this time.
At first, Sheffield cutlers refused to work with crucible steel because it was much harder than they were used to.
French cutlers had no such reservations, providing a ready market for the new steel and producing higher-quality cutlery that began to challenge Sheffield's dominance. When the British government refused the Sheffield cutlers' demand that Huntsman's exports should be banned, the cutlers were forced to start using his steel for their own products.
http://damascus.free.fr/f_damas/f_hist/perret.htm
