Got it.
For those reading this thread, I want to expand on my steel choice statement. You regularly read or see on You-tube that X steel will bend easily and Y steel will break easily, etc. This is 99% false. Most all knife steels can be made to bend, or made to break. It is all in the HT and geometry of the blade. For a sword, simple streels are a good choice ... especially while you are learning sword making. A sword is not a long knife. It has different geometry and usually a different HT. The biggest error I see in people who make knives making their first sword is they either make the blade too thick, or too hard.
Too thick:
A sword .375" thick surely will not bend or beak easily. But, it is a club with an edge on it and close to unusable as a sword. Tapers, bevels, geometry, and reasonable thickness will make a lighter sword that has sufficient strength.
Too Hard:
A sword isn't a fillet knife, or a skinner, or a chef's knife. It is a weapon, and has very different parameters than user knives. A sword doesn't need to be Rc62 .. and doesn't really want to be that hard. Traditional swords were in the low to mid Rc50's. Rc 58 is more than hard enough for most swords. Proper HT procedures and tempering to get maximum toughness is far more important. If you are just going to get the sword "red hot" in a forge and stick it in some oil, you are going to have issues. It takes a good bit of practice to properly HT and temper a sword.
Just some steel comparison info - 1084 properly hardened and tempered at 500° is Rc59/60. Do it at 600° and it will be Rc58. 80CrV2 will be Rc58 at 250° temper (get past 300° and it will drop below Rc55). For a sword, the 1084 will be a much better choice if for no other reason than the much flatter tempering curve (much more room for error and deviation along the blade).
You will have failures and successes. Figure out why some failed and some succeeded and you will learn from those swords. Jumping from steel to steel and style to style will not teach you as well as picking one steel and one basic style ... and learning to make that as perfect as possible.
Now, as to why use a simple steel over a higher alloy - The HT is simpler. 1075/1080/1084 are all simple eutectoid steels. They have the simplest HT and do not require a soak time. They tolerate a range of austenitizing temps well, and harden quite well in most any faster oil. They can also be water quenched if you are learning yaki-ire. They produce quite nice hamons.
Final comments:
We all love to watch FIF, but swords are not meant to smack whiskey barrels, tree trunks, or horse skulls.
Swords are not machetes. They are not intended to lop off tree branches and smack against things like tree trunks. Test them on things similar to what they are made to cut - firm flesh. Roll up some old carpet or newspapers, stuff a gunny sack with hay or grass, grow a bunch of melons and pumpkins, fill gallon jugs with water and screw the caps on, etc.
Swords come in many sizes, but the vast amount of user swords were fairly short. A wakizashi with a 16" to 18" blade will be more fun to make and use than a katana with a 36" blade. A European/Scottish short sword with an 18-20" blade will be more fun and easier to make and HT than a Claymore or Crusader's sword.
