- Jul 23, 2015
Did you remove the key ring lug or is it just hiding?
It's the harvester & didn't have the key ring lug. If I removed it half the scale would probably be missingDid you remove the key ring lug or is it just hiding?![]()
Lol, thought it was a Farmer who's saw can be uncomfortable to use because of the key ring.It's the harvester & didn't have the key ring lug. If I removed it half the scale would probably be missing![]()
You're not wrong there , I had a Farmer repaired (broke the awl in a fit of stupidity:dont try and pry the lock pins out of forklift forks, the awl doesn't like it) and they replaced the keyring as well as the awl. Now torn with indecision whether to re remove it or leave it in case I need to attach it (for heights work etc)Lol, thought it was a Farmer who's saw can be uncomfortable to use because of the key ring.
Vic built the Harvester right.![]()
Thanks for the warning. If the awl hadn't broke you'd have been the hero.You're not wrong there , I had a Farmer repaired (broke the awl in a fit of stupidity:dont try and pry the lock pins out of forklift forks, the awl doesn't like it) and they replaced the keyring as well as the awl. Now torn with indecision whether to re remove it or leave it in case I need to attach it (for heights work etc)
Off topic but still, that's some serious polish on that Case. Did you do that?Still with the black Alox Cadet, will be until official winter when I switch to blue.
