- Apr 15, 2012
Out of the package, and into some Big Dry Wood (first cuts out of the packaging ;-)
Not a review, just the first use application & gettin' some work done solo.
Local told me the trail was blocked by a couple large downed trees.
He kinda smiled side-ways at me :-/ when I said I just got a new pocket-saw :-o , and would check it out that afternoon.
I was not expecting such a pre-tensioned mess, but this new Silky had not been broke in yet ;-)
A few post-first-use comments:
1) The blade coating appears to be doing a better job than non-coated Silky blades I have used previously.
2) Thick bark, on larger diameter logs, clogs up the teeth (kerf) pretty fast. Learned quickly to strip the bark before the cut. At 8:50 into video, you'll notice I partially stripped the bark on the Tension Cut of 2nd cut (all remaining cuts I paid particular attention to strip all bark in cut area.) Tomahawk made quick work of this ;-) At 3:15 into video you can see the bark thickness where I cut just thru it to make a stand for my camera-phone to rest while filming the under-cut (tension cut). At 11:15 into video I show/discuss bark stripped entire circumference of saw cut area.
3) Blade Pivot came loose during cutting (you can hear some rattle occasionally). Suggest tensioning and thread-locking (done now).
4) I think the curved blade gave me more problems than solutions :-/
5) Noticed some blade chatter (bounce out of cut) with these XL Teeth (6.5/30mm aka 5.5/inch) on dry wood.
6) I find the KatanaBoy 500 too large for my pack, the Gomboy 240 nice in pocket and in use but small for pack and would have been left wanting on this project, Bigboy perhaps my Goldilocks saw
7) Grain direction of wedges should be perpendicular (opposite orientation from how we would select grain direction on a hawk haft, but similar to grain orientation of a wedge we would use for an axe handle eye).
Youtube direct link:
Silky Bigboy Outback - 1st Wood
