- Oct 24, 2008
I'm about to pull the trigger on an EKI t-shirt but I'm currently in that grey area between small and medium and it makes ordering shirts online kind of a gamble.
I normally prefer shirts to be tight around my chest and shoulders (I have broad shoulders but a small waist) and slightly looser around the waste - I hate when the bottom of a t-shirt is tight which leads to it bunching up.
Now, on Emerson's site they have a sizing FAQ but it's a bit hard to understand, I was hoping maybe you guys could help me interpret what they're trying to say here?:
Now the part in bold is what I find a bit confusing. Does it mean that if someone is a bit beefier up top then they want to go up a size while someone of a smaller frame should stick with their normal size?
I sent them an email asking the same question but I was wondering if anyone here had purchased one of their shirts in the past and could maybe offer some input.
Thanks!
Mens sizes are also true to size and if for example you wear an XL Beefy-T then any XL Emerson should fit you just fine. However, there are many ways guys like to wear their shirts and it can go from skin tight to loose and easy depending on your style. Our shirts are cut a little trimmer and could be called an athletic fit. So the best way I can describe sizing is like this; if for example, you prefer a snug or tight fitting Beefy-T in a size large then I would recommend an XL in the Emerson and you should be just right. If you prefer a loose style and get this with a large size Beefy-T then a large size in the Emerson will probably fit you just right, nice and loose.
Thanks!
