I have been seriously studying slip joint designs and trying many things out. I've made about 3 dozen slip joints and am capable of producing a well fitted and properly functioning knife, but my design needs serious improvement. The overall feel is usually good but the outline isn't appealing sometimes and frankly often times it doesn't all fit together into a neat package. My main issues are
1) i cannot hide the notch of the blade with the bolster without the bolster looking overly large or the blade not centered in the bolster when open.
2) i feel my tangs still have too much meat on them, and are often too long. If i try to shorten the tang i get the blade smacking the spring.
3) i often have the situation where i cannot round the bolster on the spring side and so it looks flat. If i make the bolster extend out further from the end it's just a lot of empty space and looks weird.
I typically use 3/32" 1095 steel. My springs are usually 1.25" - 1.75" from middle pin to the end, and have a height of somewhere between 0.060" and 0.090". For the tangs, i have usually 3/32" to 1/8" from the edge of the pivot hole to the notch. Adding it up, this gives about a half inch overall height near the pivot. The kick usually hits the spring 33% to 50% way down from the end. 50% is too long a tang, but 33% is too easy to smack the spring when closing.
The only solution i can think of is to make the spring about 0.150", take some off the belly of the spring near the middle pin so it won't be too stiff, and then taper the end from the back side down to maybe 0.060". Then i make the tang about 0.060" from edge of the pivot hole to the notch. Having a smaller tang will allow a stiffer spring and keep the same overall stiffness when opening and closing the knife. Tapering the end of the spring will keep the notch from being too deep and hard to hide.
My problem is when i try this, accuracy becomes highly crucial. I believe this is mainly due from nearly halving the preload i have been dealing with. I just ruined two knives in a row that felt good when fitting them in my ruple jig but after assembling the knife it became sloppy. I usually use the jig to setup my drill press to drill the final pivot hole in the liners, and everything went together perfectly straight and even as far as i can tell, like it always has, but just that little bit of error alters the fit up.
Any advice?
Any advice?
