JDWARE
- Nov 28, 2011
Below is a photo of the type of "galling" that I was experiencing about six years ago when I first started using stainless steel. When trying to open the blade, it was very, very difficult - not from spring pressure, but some type of extreme friction ("cold welding" as Mete suggests?) On the radiused corner of the tang is metal that looks to have been pulled, or torn from the spring. No amount of clean-up, refinishing or lubrication fixed it. I thought maybe it was a defect of the steel. I had never had the problem with O1 carbon steel blades and springs.
After not finding help online, I called Brad Stallsmith at Peters Heat Treating. Brad was kind enough to offer his help. He stated....."Hardness differences between components that rub together of more than 5 pts. will cause galling." Brad said that a large factory customer was experiencing a similar problem, and so they lowered the tempering temperature of the springs (increasing hardness) and that solved the galling problem for them.
I took Brads advice. The galling stopped. But the springs started breaking. This is when I bought a hardness tester - without one, it's all guess work.
I'm not suggesting that this is the answer to your specific problem, but it's one possibility. As others have advised, it could be lubrication, finish or geometry (or a combination of all).
Like Javan, I study the work of the old Sheffield makers. I've been surprised to see how soft the tangs and springs often are. In some of the old films and photos that show the folding knife blades being heat treated, it appears the tangs are never even hardened.
In fact, Peters Heat Treating softens the tangs (for at least one of their customers) using an induction coil to quickly heat the tang. I do it with a torch.
Saludos
J
JDWARE KNIVES
Saludos
J
JDWARE KNIVES
