- Jul 23, 2015
I've been wanting to make slipjoints for what seems like forever. I have put it off until I could get a ruple jig put together. This is what I came up with using all material I had on hand. I read about the pins wearing out the aluminum base so I decided to use some .75" W1 to reinforce the area. I made it to handle 1/8" and 3/32" pins. I still gotta finish the bottom bolt that will press up the bottom of the back spring. I have to lower the bolt closer to the surface of the jig. All I need to do now is get a good slip joint pattern and I'll be off and running.
