We may have to combine these 'peanut' threads into one......but
Being a Buck collector I try to share my knowledge of the brand, as a knife user, I envy some of the qualities of the other brands. So I try to bring knowledge and be modest in discussions and guarded in my opinions. That said here is some info. and eventually an opinion....
Buck made 305 Lancers
Group of 305s
Top three 305 lancers, bottom two 309 Companions, pre 1989 305 and 309 issues had only one spring (cami)
Heres the opinion part. If you work in an environment that made you wear - Marrin', burin' and Sunday-go-to-meetin' clothes everyday and you had a knife limit then the little 305 would be fine. But, have several and carry none. I call on the 309 to fill my small knife needs. I am a sort that if you need a "knife" bigger than 4 inches I will be getting a fixed blade out. In everyday life a small stockman is just right for me. You ask me to come to your ranch and help feed cows, or cut a bunch of new cabinets out of a bunch of cardboard boxes and I 'might' slip a big 307 in a belt sheath on. I would rather have a 305 as nothing and with skillful use it could skin a bear. Maybe not a Polar bear.......
If someone feels shorted by the 309s two blades, you might look at the 310 whittler, it is a 309 with a coping blade added. Not carried in the Buck catalog but just by Bass Pro. SMKWs may still be selling stock also.
Buck 310 Whittler, 309 with a small coping blade added. Knife on right is discontinued and a little tough to find.
310 group with traditional wooden box it comes in. Only black sawcut available.
This is for those folks that are into 'how its contructed'. I rescaled this one latter. A 309 with scale stripped off. This black sawcut material (Valox*) is hot pressed over the shield and the holes in the liner form sort of 'rivets' to hold the scale on tight.
300Bucks
