Snare wire
Ok so I hate to admit it but I'm not all that savy on my snare skills a fig 4 I can do but snare are something I never really practice nor have I included snare wire in my PSK:eek:
So I decided to remedy that. I need to run over to a hardware store or two later tonight and thought I would pick up some wire and to start fix that.
So my question to you experienced snarers out there what gauge and or type of wire would you recommend for snares and for snare wire to keep in a PSK?
are to the point you are cutting the handles off of toothbrushes to save weight,purchase a good quality commercial snares.Yes you can use picture hanging wire,shoe strings ect.,but if I'm to the point I need to set snares to survive...I'm going to use something that will hold a rabbit or a racoon..and unless the snare has a swivel on it,it might not.Check trapping magazines(fur-fish-game)for advertisers that make snares.The snareshop is another.Just because you set a snare for tree rats doesn't mean a coon won't be waiting in it when you return..:eek: have fun with that!:D
Kinda depends on what are you looking to snare: squirrels, rabbit, raccoon, beaver, deer, wooly mamath? Do yourself a favor and invest commercial grade, locking snares.
I've had good luck with this supplier: http://www.minntrapprod.com/
Martoonisotu,
I followed the link to Minnesota Trapline Products and I had no idea what to order? Which product(s) would you carry in your PSK?
Braided fishing leaders with snap swivels make great snares. Berkley makes them and they are available in a variety of sizes. I carry them in my day pack at all times. The barrel swivel makes them pretty "tangle" and kink free but they don't lock like a good professional snare (i.e. Buckshot's camp or Thompson).
If you are really space concious, get braided picture frame wire. The braided kind is much more resilient than the smooth wire. There really isn't a fair comparison between professional snares and simple wire. If you go with a 5 to 1 or 6 to 1 ratio of snares set to those that are expected to return game, you'll be carrying a good deal of plain wire around. It isn't that much more of a burden to carry professional grade snares or the Berkley leaders. Remember, carry the best you can afford and consider your gear genuine life insurance.
The last bit of advice I'll put forth is the average person doesn't need snares in a 72 hour kit. Food is low on the priority list behind water, shelter, fire and signaling. For extended outtings, carry the professional snares for genuine use. In a psk, some wire is good for utility purposes and makeshift snares in a pinch but the liklihood of using one in a short stay is very unlikely.
There is obviously a lot more to this than I assumed...which was a mistake on my part as we all know what happens when one assumes.;)
Some more qualifiers here. The new PSK I'm putting together is very much so based on the layering principle so there will be an entire altoids tin dedicated to fishing and snaring gear. So the snaring materials would need to fit inside that size tin. Will any of the pro made snares fit inside a Atoids tin and if so, how many do you think I could fit plus some basic fishing gear?
I've looked at the links you guys provided (thanks by the way) but have now idea what I'm looking at. What would you recommend I get for a PSK? Also are there any books that anyone could recommend on the subject. I'm not looking for anything for the serious trapper but a quick and simple how to guide for the novice.
"Camp Life in the Woods" is a fantastic book on constructing traps and setting snares. You'll want to pick up a hard copy, but you can read it online at Gutenberg.
http://www.gutenberg.org/etext/17093
Also check out "Deadfalls & Snares" by AR Harding.
Ron Hood has a very good video on trapping.It takes a LOT of practice to know how to use snares.Snare height,snare size,ect.,If it's legal in your state get some snares and learn how to do it.Always be prepared.Sometimes the critters will be very much alive when you get there so you must have a way to dispatch it.If you snare a deer..and if it's still alive when you get there...putting it down without a weapon will be something you won't soon forget.....
I have used copper wiring removed from a broken lamp, just strip the coating and choose how many wires to braid into appropriate snare.
I have also bought 20 guage brass wire from hardware stores for use as snare wire.
If you can find sewing machine bobbins, they make great carriers for snare wire (& fishing line) because they are so compact. You can tuck them into just about anything.
I use, and recommend, about 20 gauge wire for snares. You can use it for small ground squirrels up to coyote-sized critters. For small stuff like squirrels, the wire attached to a carved wooden stake is enough. For larger game, tie the snare wire to 550 paracord, then tie the paracord to the wooden stake. These are simple snares that do not use an "engine" to work (an engine being a twitch-up or other trigger method that uses the energy of a branch or other kinetic means). A simple snare only uses the critter's momentum and direction to work.
As long as you know and recognize sign and tracks, you can easily snare critters. Think about their head size, and the height at which they normally plod along. Then you can set the loop to be just big enough for the game you want, and you can set it to be at the height their head will naturally go through when they are "walking."
Things to consider: de-scenting via smoke (critters are not alarmed by the smell of campfire smoke in many places as they are used to campers), or rubbing mint leaves on yourself and the wires/wood/paracord; also be prepared also that your snare may not kill an animal, only harm it irreversibly, so you may have to finish it yourself. If you have not been in the position of having to kill an animal with your knife or other up-close method, it can be very disturbing. The first time I had to behead a squirrel I snared, I held it up by the tail. It twitched its legs and arms (the head was removed) and kept up these convulsions for what seemed like an eternity. So, be ready.
Constructing a snare is easy. It's placement that is the big challenge.
Martoonisotu,
Sorry about the confusion. That website could use a little bit of improvement. They do have a nice catalog however.
Here's an easier solution, pre-fab snare kits from Buckshot's Trapping. Let your budget and quarry guide your purchases. If nothing else, get a book/DVD and start learning the basics.
http://www.buckshotscamp.com/Snare-Kits-Sales.htm
(Also a good supplier...slow, but good.)
Thanks for the useful link! I am going to order one of the emergency snare kits.
Don't forget to prep (season) your snares:
To prepare snares, boil them in water with 1 cup of baking soda and place outside to weather. The snares don’t really rust, but will become dull after 10 to 14 days. You don’t want to use shiny snares for animals.
source: buckshotscamp.com
:thumbup:
You will not catch me using snares here 'cos it's illegal. From a pragmatic angle, there aren't that many places where I can be absolutely confident I will not take a domestic animal. Last, my own moral compass forbids me from using methods that can introduce unnecessary suffering, as other methods are available. That said, I have used them with good effect. I've never been a fan of steel wire jobs, or any other wire with a memory come to that. The ones I have bought have always been braided brass wire. When I gave up buying them I just made them from stripped copper wire from electrical flex, nuts and bolts, and various fishing tackle fittings.
I recently read on another forum that a guy carried a regular rat trap, and had used it with simple bait to catch various animals while out in the ‘bush’. I know it’s not minimalist and is potentially illegal in various places, but in a true survival situation, you’ll need to be found before worrying about fines.
I know nothing about snares, and have no legal place to practice this skill. A trap certainly seems easier to me, but of course the space/bulk penalty might not make it worth it. Perhaps the metal could be removed from the wood base and tied or wood screwed into a tree limb, thus saving both weight & bulk.
G
