I see rockwell hardness numbers thrown around a lot, but I've never really seen anything that clearly defines how much harder 60 HRC is than 59 HRC. I looked around at the way the HR numbers are actually calculated, and found that in terms of measuring the depressions and everything that are actually used to get the hardness value, there's only a .000079" inch difference in depth in steel per HRC point. So I could then pretty easily visualize/imagine how deep each particular hardness value is penetrated--for example steel at 67 HRC will be penetrated .0025" into the steel, where as the diamond cone intender would penetrate .0035" at 55 HRC.
So at least that gives me a bit more sense to the level of difference between each value, but just knowing these numbers don't really translate into how much more wear resistance or how much more tensile strength a particular steel has at a particular hardness level. So I guess when someone compares 58 HRC to 60 HRC, how do you really quantify that difference?
I get the feeling that it's simply a matter of researching/studying how certain types of steels perform at varying hardness levels and then using that experience to decide on the appropriate value?
