I usually don't soak as in leave the handle in a jar full of mineral oil. I just apply with my fingers heavily, rub and work it in good and let it set a few minutes or over night and then do the same thing again. I usually reach a point where the oil just wants to lay on the surface and not do much, then you know your there.
I do that a couple times a year or more if I'm fondling and they seem thirsty.
Wood may need it even more frequently depending on the wood and how dense it is.
I don't see soaking it doing any harm but on a good fitting handle I don't want to risk impacting the wood to metal fit or weaken the Laha any at all.
You do need to keep wood paper contact with the oil or it will be spotty and leave gel residues that are a pain to remove.
Interesting. I so far have just been wiping the blades with Rem-oil. I use museum wax on blades that I plan to store for a long time, I need to work out a good plan for the various levels of useage. Ways to prep a blade for long term storage, ways to prep a blade I intend to use fairly regularly and ones that are Always in use. Khuks are great tools they deserve to be maintained right so they can continue to serve well for decades....
I havent tried that Pugs but it does make perfect sense! I think the mineral oil is thin and soaks in well and if you soak in BLO afterwards you would get the polymerization and sealing you want without the surface oil! Brilliant man! Thats what makes this place so Khul! I just happen to have a new Mini AKB to try it on:thumbup:
