Here's all I have. Not sure what color / patina / texture you're looking for. Never heard of a peroxide / bicarb mix...
1. Gun Bluing.
The simplest (and the most easily obtained) way to patinate brass and copper based artifacts is with commercial gun bluing solutions.
Start with a volume of water just large enough to immerse your item. Warm water works faster.
Thoroughly wet the piece in water to drive off any air bubbles. The patina will not colour under the bubbles, resulting in bare spots.
Immerse the piece in the water, and slowly add small amounts of gun blue to the water until the artifact starts to brown. Be sure to gently and continuously agitate the solution over the piece.
When the piece has developed a blackish skin or ‘fuzz’, take it out, and with a soft brush (like a toothbrush), wash it under water to see if it has developed the colour you want.
If you want it darker, re-immerse it and repeat the process.
Neutralize the piece with a wash of baking soda and water and rinse well. Dry the item completely and seal the patina with your choice of either a wax or Tung oil.
2. Brown (light to dark)
Chemicals: Ferric Nitrate - ½ teaspoon
Distilled water - 1 pint
Method:
Heat the metal until a drop of water sizzles on its surface.
Brush or spray on the solution while constantly reheating the metal, until you achieve the desired colour.
You can get any shade from a chestnut red to a dark brown, but try not to burn it by applying too much heat.
3. Brown to Black
Chemicals: Potassium sulfide (aka sulphurated potash or liver of sulphur) - a flower or lump the size of a nickel (it has to be fresh, or it won’t work).
You can tell if it is fresh by the colour: yellow is fresh, dusty white means it’s garbage.
Method:
Use the hot process or immerse in warm solution.
Do this outside as it smells strongly of rotten eggs (the sulphur you know!)
4. Greens
Chemicals: Cupric Nitrate – 1 teaspoon
Method:
Apply to heated metal with brush or spray method. Build up applications to the desired depth and colour.
5. Olive Green
Chemicals: Cupric Nitrate – ½ teaspoon
Ferric Nitrate – ½ teaspoon
Distilled water – 1 pint
Method:
Heat metal and apply.
6. Cold Process Green.
Chemicals: Cupric Nitrate – 40 gm
Ammonium Chloride – 40 gm
Calcium Chloride – 40 gm
Distilled Water - 1 Litre
Method:
Use the cold process. Several applications are needed.
(One can also get a great brown green by urinating on the piece at interval—and it smells like it for ever and ever.)
7. Reddish brown (cast brass)
Chemicals: Cupric Sulfate - 125 gm
Sodium Acetate -12 1/2 gm
Distilled water - 1 Litre
Method:
Boiling immersion for 10 – 15 minutes. The colour will develop after 10 – 15 minutes.
8. Red (cast brass)
Chemicals: Cupric Nitrate - 8 oz
Oxalic Acid - 8 oz
Distilled Water - 1 gallon
Method:
Further Reading
For more recipes and techniques, check out Richard Hughes’ and Michael Rowe’s book, ‘The Colouring, Bronzing and Patination of Metals’.
I’ve been using it for years. It has lots of colour plates.
Good luck, and remember to patinate outside!
