You'd have to do something stupid to break a CS Recon1! I own 4 variants of them. If I were you I'd grab a carpenter steel model before they are all gone. If you don't care for it it'll be an easy sell here. That's my favorite EDC knife. Try it!I'd like to upgrade to a bigger knife for outdoor use. I usually carry a Sog Pup (5" blade) .
These 2 caught my eye. I am a bit worried about the Recon 1 due to a few videos where the
Knife broke. What are your thoughts?
you talking recon 1 as in the folder with tri-ad lock....or recon scout as in 01 fixed blade?I'd like to upgrade to a bigger knife for outdoor use. I usually carry a Sog Pup (5" blade) .
Yeah, you're going to need to be more clear on what you are looking at.I'd like to upgrade to a bigger knife for outdoor use. I usually carry a Sog Pup (5" blade) .
From context , I assume you're talking fixed blades . I'd go with Cold Steel over SOG . The CS Recon Scout or Trail Master in 01 will be tougher than the SOG in AUS8 . You can break ANYthing .I'd like to upgrade to a bigger knife for outdoor use. I usually carry a Sog Pup (5" blade) .
So long as you get the real thing (beware the many clones and copies ) a Recon Scout in 01 (or the old Carbon V ) will deftly handle any wood chopping chore . Not the best to baton because of the guard .Oooops! Yes I meant Recon Scout...the fixed blade. My bad.
I won't be doing anything harder than whittling or chopping up to a 2" thick stick.
I've chopped down medium sized hardwood trees with my 01 Trail Master with no damage to the blade .
Best way is to buy from a trusted source , like Blade Forum sponsors . But right now is bad timing . The older Recon Scouts have been discontinued and are out of stock most places . The newest A2 steel models aren't yet in stock either . Probably gonna be a lot more expensive , also .How do you know the difference between real and fake 01 Scout Recon. Logos or stamps give it away? I’m new here. Been a Spyderco and Benchmade folder and now looking into Fixed blades, particularly the Scout Recon and the Pendleton MiIni Hunter
