I've had the SOG Twitch II with spring-assisted flipper for about 6 months now and would like to share some thoughts and pictures. The blade is 2.7 inches, handle 3.5 inches, for an overall of 6.2 inches and a weight of 3 oz. The clip is mounted right side only. The blade is shinny satin finished, the scales are annodized alumiunum (quite durable), and the other parts bead blasted steel.
A shot closed:
The lock on the Twitch II is a "pass-through lockback design." The lockback is split into two to allow the flipper to pass through it. The halves appear to be bonded to eachother as they cannot move independently. In most senses, it is a lockback, although it employs a stop pin. The stop pin makes the blade rigid in the positive loading direction. Although if you grasp the blade and the handle in two hands and jiggle them with moderate force, you can feel some play. The same applies for sideways blade play: you don't feel it normally, but it's there if you jiggle it with both hands. The "thumbstuds" functionally provide a stop-pin in the closed position and to thumb the blade open if the the blade doesn't fully open (which never happens with the right pivot tension unless you block the blade youself). Pressumably, it also partially disguses the "auto" look.
On the clip side, the main pivot "hub cap" hides a coil spring. This part can be opened to be serviced or to remove the blade. Turning the "hub cap" adjusts the blade tension, but I was not able to dissamble the rest of the knife. The body of the other pins just rotate with the head when you turn them.
There is a safety behind the lockbar release, which limits the locbar moment to allow a positive lock in the Closed direction. The safety is not effective in preventing the lockbar from being depressed and the blade being closed. In my experience it has not been necessary to use lock the knife closed in order to carry it.
Here top shot and side shot along with a Vic Climber and an Cadet. The blade length is about the same as the main SAK blade. The handle thickness not regarding the clip is about that of the Cadet, and half that of the 3-layer Climber:
The blade stock is pretty thin, flat ground with an apparent distal taper (probably partially because the point drops too). It is throughout its length only slightly thicker than the SAK mainblade. The primary grind is not as agressive as the SAK though, leaving the edge considerably thicker. The Twitch is pictured with an approx 30 degree total factory bevel.
More to come in a min...
A shot closed:
