SOLD Kobalt Xtreme Access socket set
Feedback: +101 / =0 / -0
I am clearing out more stuff that I don't use often and decided to put these out there. These are the Xtreme Access set from Kobalt. I will list what is all included below. These are in great condition. I bought these a couple years ago, but pretty much stopped working on cars shortly after. I think I used these maybe two or three times, the sockets all look new, the ratchets have some scuffing, but function perfectly. They have been stored inside, were wiped down after use, and have no rust. I bought these all at the same time, but not in the "set" case, so technically there are 36 total "pieces" here. These were made in Taiwan and are very good quality.
-3 ratchets, one for each size socket
-adapters to use regular sockets with access ratchets
-large sockets, sizes 18mm(23/32)-25mm(1)
-medium sockets, sizes 10mm(3/8)-19mm(3/4)
-small sockets, sizes 4.5mm(3/16)-13mm(1/2)
Paypal and lower 48 only, if you happen to be local, and can pick up, I will cut you a deal, as shipping is included in price. $SOLD
Thanks,
Bruce
How tall are the sockets and wrenches when combined? How small a spot can they get in and work on? Interested as I unfortunately have kids , ol lady and my vehicles I wrench on when needed :(
Doing some rough measurements- 1 1/2" total for largest wrench+socket, 1 1/4" for medium wrench+socket, 1" for small wrench+ socket.
These are definitely quite a bit slimmer than your standard wrench+socket.
Bruce
This is the best pic I could get. This is the extreme access large wrench with 22mm socket in front of a regular 1/2" wrench with 22mm socket. Both wrenches are the same length. Hope that helps.
Bruce
FWIW,
I've got the same set(s) for use in our trucks and the Rover. The absolute best part is the "pass-thru" for longer bolts...no need to carry any Deep Well sockets at all. Between these and a high quality adjustable wrench you're covered for almost anything bolt/nut related. I actually picked up a single larger socket for the lugs on the quad (Honda specific size of course :thumbdn: ) and with the 12" extension ratchet any tire change is that much easier.
One of the most practical pcs of gear you can find for the vehicles
