SOLD
The 2 x 72 belt machine is a KMG using a 2 HP tefc motor which is hinged to the aluminum clad base. This machine doesn't have many hours on it and it runs very smoothly with great tracking. It runs a 3 belt pulley system. The machine has two different work rest which you can see in the photos. The large work rest is great for grinding large blades. Lots of space to work. This grinder comes with an extra tooling arm. This is also a very strong machine. Runs quiet, never abused. Wired 240 volts.
The base is a Makita tool dolly rated at 350 lbs. It raises and lowers using two hydraulic cylinders and a set of strong arms. The top is clad in heavy aluminum sheet to protect the surface. The machine was just cleaned and is ready to be used. $1500.00 firm
Pick up only on this machine; we are located in Washington co. Ohio. Down by the Ohio River. 866-325-2164 if you have questions. Fred
