Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Some good info here guys! Thank you and keep um coming!
I don't know what Benchmade is using these days, but all 5 of the original AFCK's that I've owned new from the manufacturer had red loctite. The first and only screw I ever stripped on a knife was a screw on one of those knives.Have you tried just using hand pressure? No knives that I know of have red loctite on them anywhere. Blue should be easy to break from hand pressure alone and a good bit, well seated in the screw.
No soldering iron required.
From what I've read on this forum some knife manufacturers use very cheap, soft screws and lots of loctite. That's a bad combination. Whether it's actually needed or not a few seconds with a soldering iron is a lot less hassle than dealing with a stripped screw in a knife.
My soldering iron is a Weller soldering gun with 100 and 140 watt settings. I bought it at Home Depot. I had tried a cheap 3M soldering iron from Walmart but it was a piece of junk that wouldn't heat up enough to melt solder.
For most knives I don't need it indeed, but the screws from my PM2 won't come loose by hand. Even not when I keep the knife in boiling water.
