- Oct 19, 2011
I read a bunch of threads about soldering. I printed out a couple of Stacy's posts about soldering and read it a few times. The solder I was using was a "pro soldering kit" I ordered from Jantz. This is a roll of Stay-Brite with the matching bottle of paste flux. I cleaned the brass guard and the knife blade (1084) very well. I washed my hands and used nitrile gloves so I wouldn't contaminate the pieces. The guard fit was tight and needed to be press fit. Although, when lubed with the flux, it went on easier that I expected. I placed the end of the tang in the vise with the blade tip up. I applied flux to the guard and the blade at the joint area and fit the pieces together then began to add heat from the tang just behind the guard. I used a heat gun with a reduced nozzle adapter for a more concentrated blast of heat. I took a LONG TIME to try to get the joint up to temperature while keeping the heat moving constantly so the joint heated evenly from all sides. I kept touching the solder to the joint to see when it was ready to flow but it never did. After a long while I thought maybe the heat was insufficient so I stepped it up a bit with a propane torch. Still using a soft blue flame. The solder still wouldn't flow. The flux was still liquid at that point and not over-cooked. Then the solder started to get soft but instead of flowing it just kept breaking off in very consistent 3/8" or so segments. That was strange. Eventually I got frustrated and took it all apart, cleaned it to fresh bare metal and epoxied it. I know.....quitter. But, I still want to learn how to do this. Does anybody have any ideas why the solder wouldn't flow or why it kept braking off in little pieces?
