David Martin
Moderator
- Apr 7, 2008
Glad some folks brought up a possible poor heat treat. The high V and composition can make it a trick to heat treat. Sounds like your on your way to working things out. Good. DM
I strongly suspect that the answer for you is a different steel. Why put up with something finicky and (apparently) hard to heat treat when there are so many much better steels out there? Check out some listed on my first post, you'll never go back. Shoot, even CPM 3V, not at the top of the edge holding list, easily beats S30V by a substantial margin in edge holding and is much tougher. I've never had a stinker in that steel yet, and I find it very easy to sharpen. There are lots of others as well. Choice is good.I don't claim to know exactly what's going on here... it's part of the reason I posted. I did two more days of minor testing on this blade. It's now gone through a total of around 40 feet of cardboard, and yesterday I opened a Hello Kitty flashlight in a blister pack. Some of these blister packs are made of surprisingly thick plastic, though this one was a more reasonable thickness. The 3 year old that owned the light was thrilled to have it in her hand BTW.
After all of this testing the results are very similar to after the first round: It only cuts phonebook paper very roughly and parts of the edge won't even catch the paper. Printer paper cuts mostly very cleanly, though it's "loud" indicating a rough edge. There are a few spots that catch a bit on printer or magazine paper, which is to be expected I think. Perhaps most importantly of all, that flat reflective edge has NOT reappeared. I'm sure it will eventually, but I hope only after a bunch more cutting.
This is much more like it. An edge that will clean slice printer paper for a very long time is very useful to me day to day. Now, what I would LOVE to have and I'd pay premium money for, is an edge that will go through this and more and hold a shaving edge. I don't think it would necessarily be very much more useful from printer paper slicing to shaving... but it would be really fun!
Did I have a very small burr? Frankly I kind of doubt it, but it's possible. If it's *my* technique that's causing this flat edge to appear after light use, I'd expect it to happen again eventually. If it does, I'll be honest and post about it here.
Brian.
Since my last post, I've used the CPM-S30V Yojimbo 2 blade quite a bit, did a few SharpMaker sharpenings, and finally a full DMT sharpening. Honestly the edge holding hasn't changed since my 2nd session with the SharpMaker 4 to 6 weeks ago. It's still doing "ok" in that it can't hold a fine edge for long at all, but holds that slightly reflective "working" edge for a good while.
Yesterday I tried a "destress the edge" sharpening, where you cut the edge directly into a stone to remove any weak metal and then sharpen as usual. This is the sharpest I've been able to make the Yojimbo 2, but I don't expect it to hold it very long. We'll see. I honestly think that, as good as S30V is, it's not what I want. I want a steel that holds a fine edge for 10x as long as 8Cr13Mov. 5x as long would be good, but 10x is really what I want.
I guess I need to find a blade style I like in S90V or S110V then?
I'll report back if the edge holding has changed at all due to my latest sharpening.
Brian.
I think S30V should be sharpened with diamond .Don't press with diamond you'll pull out the carbides..It will cut anything ,let the diamond do the work. A micro serrated edge works best for me. Touch up rather than let it go very dull.600,800, 1200 ,grit , take your pick.
yeah i was going to suggest this . beat me to itI would definitely grind all the factory edge off and start over. Many edges from the factory have wasted steel along the cutting edge. I don't care if its a cheap kitchen knife, should be able to cut many feet of cardboard without failing as you describe.
So , do you still don t like S30V or you learn how to sharpen itHeavyHanded posted his suggestion more than 6 years ago. I followed it.
So you're right. But you're just a *little* bit late to the party.
Brian.
Insults like this are completely unnecessary. Lot's of us don't like S30V, for many good reasons.So , do you still don t like S30V or you learn how to sharpen it
