Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Have you guys and gals noticed the sound of some blades have a more higher pitch that others? My take is that ring gives a little indication of how hard that metal might be. I may be way off point, but when a blade gives back a clean high pitch ring as you bring it in contact with a ceramic stone, it just seems that it is a bit harder and I've found those blades take an edge a little easier. Such as getting and removing the burr, they are not likely as much to have a burr that just hangs on and on, flopping back and forth as you try to get it removed. The harder blades the burr removal seems straight forward.
I recently got a very nice small fixed blade from
navman
in S90v steel, fairly thin behind the edge and hollow ground, so those three attributes probably aid in the higher ring sound when the blade contacts ceramic. Similar knives that are supposed to be heat treated as high or higher don't always give that audible feedback.
His blade also has a nice peaked spine, and a tapered tang, more work but all adds up to a nice knife.
Untitled by GaryWGraley, on Flickr
another knife that gives this type of feedback is a Civivi Trailblazer in damascus, an amazing edge on this one
So, have any of you noticed this type of thing? Some that do not take a very good edge sounds dull which I figure means it's not hardened very much.
G2
G2
