*I'm just cleaning this up some since it looks like the formatting took a hit when the new website launched or something. I'm not changing any numbers here just getting rid of the extra figures that are showing up, specifically the "”"*. I took out some busse content since I am limited in characters.
-bikerector
The following list is for reference purposes.
*** Please keep in mind some specs can and do sometimes vary a bit from knife to knife. Sometimes the same knife is released at different times with slightly different grinds, thickness or handle materials. I have tried to specify significant variations in grinds such as "Full Flat" vs. Saber grind - when and where relevant. But, even with essentially same grinds and "visible" appearance, weights can vary.
Typically, Busse and kin lengths per knife are VERY close and consistent. Most knife weights with same grinds and handle options are pretty consistent, but weights are more prone to variance than dimensions.
G10 is known to weigh more than micarta. Hand shaped scales, magnum scales and similar scale variations from Busse can cause weight variences, along with "Variant" grinds, etc.
Blade lengths are measured from end of handle material to blade tip.
Res-C handles typically have less handle material forward of the grip than micarta/G10 scales. So, handle shapes and sizes forward of the grip area affect measurements of "Reach" of the blade from the grip.
(SY) = Scrap Yard
Busse knives listed at bottom.
Folder
Rat Trap Folder (S30V) = 4.375 oz; .1875;; 3.9; blade; 9; oal
Skeletons:
RIP (Rat Ice Pick) (SR101) = 2.2 oz; .1875"; 8" oal
Rat Tail (SR101) = 3.2 oz; .1875; 3.75; blade; 7.75; oal
Rat Shaker (SR101).. = ??? oz; .25; 2.5 blade; 5 oal
Rat Shaker II (SR101) = ??? oz; .25; 2.5 blade; 5 oal
Swamp Rat Warden 2007 (SR101) = 2.6 oz; .185" - .1875"; 3.0 blade; 7 oal
Swamp Rat Warden 2010 (SR101) = 2.2 oz; .135" - .15"; 3.0 blade; 7 oal
(SY) Scrapivore CG (SR101)(58-60 RC) = 1.8 oz; .125; 2.75 blade; 6.5 oal
(SY) Scrapivore LE (SR101)(62-64 RC) = 1.8 oz; .125; 2.75 blade; 6.5 oal
(SY) Dog Booty (Sandvik 12C27 - 58-60 Rc) = ? oz; .175"; 3.5" blade; 7.25" oal
Mudders:
Bog Dog (D2)... = 4.65 oz; .14"; 4.75" blade; 9.56" oal
Bog Dog (SR101)= 4.9 oz; .15"; 4.75 blade; 9.56 oal
(SY) SS4 (INFI).... = 5.4 oz; .2"; 4.25" blade; 9" oal
(SY) S5CG (SR101) = 6.75 oz; .185; 5.125 blade; 10.0625 oal
(SY) S5LE (INFI) = 6.6 oz; .169; 5.125 blade; 10.0625 oal
(SY) Mud Puppy (LE) (154CM) = 5 oz; .185; 3.25 blade; 8.25 oal
(SY) ScrapMuk (154CM) = 6 oz; .1875; 4.5 blade; 9.125 oal
(SY) Bird Dog (LE) (154CM).. = 3.95 oz; .125; 4.5 blade; 9.5 oal
(SY) Wiener Dog (154CM) = 3.80 oz; .125; 3.75 blade; 8.75 oal
Small Res-C handled knives:
(SY) Scrap Max 340 (ELMAX) (60-62 Rc) = 3.30 - 3.4 oz.; 0.095"; 3.375" blade; 8.25 oal"
(SY) Scrap Max 460 (ELMAX) (60-62 Rc) = 3.25 - 3.45 oz.; 0.095"; 4.5" - 4.6"; 9.1875" - 9.4"
Bandicoot (SR101) = 5.25 oz; .1875; 4.5 blade; 9 oal
Howler - 2nd gen (SR101) = 6 oz; .1875"; 4.5" blade; 9" oal
(SY) Yard Keeper LE (SR77) = 7.5 oz; .268"; 4.5" blade; 9" oal
(SY) Yard Keeper CG (SR77) = ? oz; .1875"; 4.5" blade; 9" oal
(SY) Dumpster Mutt CG (SR77) (Saber - small handle) = 9 oz; .27"; 5.25" blade; 9.75" oal
(SY) Dumpster Mutt LE (SR77) (full flat - small handle) = 7.7 oz; .25"; 5" blade; 9.5" oal
(SY) Dumpster Mutt DC (SR77) (full flat - larger handle) = 7.7 oz; .25"; 5" blade; 9.5" oal
(SY) 311 (SR101) = 5.0 oz; .1875"; 3.5" blade; 8" oal
(SY) 511 (SR101) = 6.75 oz; .1875"; 5.5" blade; 10" oal
(SY) War Dog (INFI) (Full Height flat - satin) = 6.2 oz; .235"; 5" blade, 9.75" oal
Small - Medium micarta/G10 handled knives:
Rodent 3 (SR101) = ? oz; .1875"; 3"; 6.875"
Vexillarius (Linen) (D2) = 5.25 oz; .14; 3.75 blade (from front of choil); 8.25 oal
Rodent Solution (SR101) = 6.4 oz; .1875"; 3.5" blade; 8.125" oal
Rat Hunter (SR101) = 7.5 oz; .1875; 4 blade; 8.25 oal
Safari Skinner (D2).. = 6.75 oz; .125; 3.75 blade; 8.75 oal
SAR Rat (SR101) = 10.2 oz; .25; 4.5 blade; 9.5 oal
HCLE 3.5" blade Reg. Release (G10) (154CM) = 6.4 oz; .17; 3.5 blade; 8.25 oal
HCLE 3.5 blade (2008 SE micarta) (154CM) = 6.25 oz; .17; 3.5 blade; 8.25 oal
HCLE 4.0 blade (2008 SE micarta) (154CM) = 6.5 oz; .17; 4.0 blade; 8.75 oal
HCLE 4.0 blade (2010 G10) (154CM)......... = 6.7 oz; .17; 4.0 blade; 8.69 oal
Dog Skinner (black micarta) (D2).. = 7.25 oz; .15; 4.25 blade; 9.4375 oal
Dog Skinner (2-tone micarta) (D2) = 7.5 oz; .15; 4.25 blade; 9.4375 oal
HRLM (micarta) (SR101) = 9 oz; .19"; 4.13" blade; 9.3" oal
Rodent 4 (SR101) = ? oz, .1875"; 4.625" blade; 9.5" oal
Desert Jack (micarta) (SR101) = 10 oz; .175; 6 blade; 11.25 oal
Ratmandu (G10) (SR101)..... = 11 oz; .189"; 5.3125" blade; 10.5" oal
Ratmandu (micarta) (SR101) = 9.4 - 10 oz; thickness varies over the years - reports of: .173", .189", .2" thick; 5.3125" blade; 10.5" oal
RatManDeaux (RMDx LE) (Black Paper micarta) (SR101) (FULL Height Convex grind) = 12.2 oz; "approx." .1875"; 6 blade; 11.25 oal
M6 (SR-101)(micarta) = 16.2 oz; .235"; 6" blade; 11.68" oal
Rodent 6 (SR-101) - (Convex/Saber) = ? oz; .25"; 6.375" blade; 11.75" oal
Mini Mojo (SR101) (blade catch) (micarta) = 17.6 oz; .245; 6.875 blade; 12.625 oal
Mini Uncle Mojo (SR101) (No blade catch) (micarta) = 17.3 oz; .245; 6.875 blade; 12.625 oal
Larger Res-C Handled knives:
(SY) Scrapper 6 LE (SR77) = 12.7 oz; .268"; 6.25" blade; 11.44" oal
Camp Tramp (SR101-Diff.TempLine) = 14.4 oz; .24"; 7.325" blade; 12.5" oal
(SY) 711 (SR101-ThroughHard)..... = 14.6 oz; .25"; 7.375" blade; 12.5" oal
(SY) Yard Guard (SR77) = 16 oz; .277"; 7.25" blade; 12.4" oal
(SY) SODCG (SR77) = 15.7 oz; .264"; 7.5 blade; 12.5 oal
(SY) SODLE (SR77) = 13.85 oz; .25; 7.5 blade; 12.5 oal
(SY) Regulator TT (Test Team - Full Flat) (SR101).... = 14.65 oz; .333; 7.5 blade; 13 oal
(SY) Regulator MO (Military overrun - Saber) (SR101) = 15.8 oz; .333; 7.5 blade; 13 oal
(SY) De-Regulator (Saber -single quillion) (SR101) = 15.8 oz; .333; 7.5 blade; 13 oal
(SY) Regulator Mil Overrun 6.5 (full flat - Modified tip) = 13.6 oz; .333; 6.5 blade; 12 oal
Battle Rat (SR101) = 16.5 oz; .24; 9.375 blade; 14.4375 oal
Battle Rat (Satin) (SR101) = 15 oz; .23; 9.375 blade; 14.4375 oal
Battle Guard (SR101)....... = 16.2 oz; .24"; 9.375 blade; 14.4375 oal
(SY) 911 (SR101) = ? oz; .25"; 9.5" blade; 14.5" oal
(SY) Dog Father CG (SR77) = 20.1 oz; .275; 10 blade; 15.125 oal
(SY) Dog Father LE (SR77) = 17 oz; .25; 10.0625 blade; 15.125 oal
(SY) 1311 (SR101) = 18.8 oz.; .1875"; 13.5"; 18.25" oal
Larger micarta/G10 handled knives:
Taz Rat (micarta) (SR101) = 16.7 oz; .22"; 7.375" blade; 12.9375" oal
Ratweiler (micarta) (SR101) = 19.8 oz; .25; 7.5 blade; 13 oal
Chopweiler - (micarta) (SR101) = 19.1 oz; .25; 7.5625 blade; 13.1875 oal
Chopweiler (G10) (SR101) = 20.5 oz; .25; 7.5625 blade; 13.1875 oal
M9LE (Full Flat - G10) (SR101) = 19.35 oz; .23; 9.125 blade; 14.875 oal
M9CG (Saber Grind) (SR101).. = 20.8 oz; ???; 9.125 blade; 14.875 oal
R9LE (aka: Rodent 9) = ? oz; ?" thick; 9.5" blade; 15.25" oal
R9CG (aka: Rodent 9) = 22.7 oz; .25"; 9.5" blade; 15.25" oal
Rat Mastiff (micarta) (SR101) = 21.7 oz; .25; 9.75 blade; 15.375 oal
Rat Daddy-LE (SR101) = 21.8 oz; .25; 10.5 blade; 16.25 oal
Rat Daddy-CG (SR101) = 22 oz; .25; 10.5 blade; 16.25 oal
Hatchets & Axes:
Paul's Ratchet (SR101) = 13 oz; .25; 2.9375 blade; 9.25 oal
A2T Ratchet (SR101) = 13 oz; .25; 2.9375 blade; 9.25 oal
Crash Rat (SR77) = 29.8 oz; .25; 3.75 edge; 3.5 spike; 14.25 oal
Kill Devil Sniper Hawk (micarta) (SR101) = 22 oz; 3.125" edge; 7" head height; 3.128" spike; 15.5" oal
Rattle Hawk (micarta) (SR101) = 26.5 oz; 3.5" head height; 3.5" spike; 17" oal
Swords:
Rodent Waki (G10) (SR101) = 33 oz; 0.195; 17.0 blade; 27.625 oal
Rodent Waki (micarta) (SR101) = 31 oz; 0.195; 17.0 blade; 27.625 oal
Rodent Rucki (SR101 58-60 RC) = 27 oz; 0.1875"; 15.25" blade; 23.25" oal
(SY) Scrapizashi (SR77) = 29.2 oz; .19; 17.375 blade; 27.25 oal
Busse Knives for comparison:
A good source for a much more complete list of "Busse" knife specs can be found at
BusseCollector.com :
http://www.bussecollector.com/catalog/
Another good source for Busse knife info and specs at
HogCult.com :
http://hogcult.com/chart
