- Dec 30, 2009
I have a knife I am trying to take apart because the lockbar needs adjustment, but I can't remove the screws because the female side of the bolt just spins in the frame. The screw heads are flush with the frame on both sides so I can't grip them and only one side is cut for a torx bit while the other is smooth. I have tried applying outward pressure (both by wedging folded paper between the handle slabs and by applying pressure against the blade
) but the bolts still manage to spin.
I figure that they must have had some method in the factory in order to tighten the bolts down in the first place but how did they do it? It would be a serious bummer if I couldn't get this knife apart because the lockbar doesn't go in far enough currently and is causing up and down play. Also sending the knife in to the manufacturer is not an option, I either need to find a repairman with the right tools or do it myself but any suggestions within that would be greatly appreciated! Thanks guys!
TL;DR Can't remove bolts holding together frame because both male and female sides spin! How do I take this knife apart?
Thanks,
-Fire_Brand
Thanks,
-Fire_Brand
