Hey Guys....
what about wiring a starter off of a BBQ? They handle some serious heat and keep working.
One thing about using a stun gun is that they are illegal in canada. Source:
http://www.canlii.org/ca/regu/sor98-462/part82989.html
Yaa the electrodes can handle the heat really well.. The Body of the button doesn't handle the heat worth $hit..
I'll never build another with the button sunk into the expansion chamber..Only mistake I made with this spud gun..
As for the Stun Gun...
Yaa I know...
It's not a Stun gun anymore once I'm done with it...
Spark plug?
Rip apart a small, old 2-stroke motor and take all the ignition pieces. Use a cordless drill to spin the crank.Pulse-jet builders do it all the time.
Too complicated. I don't even like the idea of having to carry batts with me...
What do you guys use as propellent. I have tried gas from a butane lighter refil can? Never had any luck. Neither have the guys in the office.Where do I find instructions as to how to build and operate?
Tim...
The best fuel I've found is propane... Cheap, Easy, Clean and gives a Great punch...
The problem with these other fuels is that your spud gun starts to stink, they get sticky inside and excess fluid is always running out of them..Spray your electrodes by accident and the ignition would work..This may be why it isn't working for you..
Also if you use too much fuel, ignition won't happen, not enough oxygen.
TOTC...
I've done a few stun gun builds. They all ignited with far more success than any other build I've done (the majority of which were piezo grill button systems). I would highly recommend it. The electrodes in the chamber will still dirty up eventually, and require some cleaning to get back to their full ability, but it's really an easy system.
The only caveat is you should remember to take a set of spare batteries out into the "field" in case you go low. The stun guns I used all were pretty good at letting you know when they were getting low: the crackle of the arc would sound slower and slower in pulse.
I haven't used spud guns in years, but they are a lot of fun.
OK Cool...
That's whats going to happen then..
Now a couple of questions!! LOL
Normal wire should be Ok to connect the electrodes with Eh ??
I'm planning on running the wiring inside so it doesn't look like crap, but have to keep the electrodes close to the end of the chamber so they can be cleaned...I'm not quite sure how to stagger the electrodes though, especially proper spacing..
I'm also going with a Exhaust/Mixing fan and one way valve, as well as direct propane feed and throw valve,, but won't be metering the fuel.
Enix...
a taser is absolutly THE best way to go w. spud guns. shoot some screws into the chamber and wire them up in parrallel(sp?). depending on the length of your chamber 6 stagerd scrws should work fine, this will disturibute the spark through the whole chamber instead of just in one spot. then disasembale(sp?) the taser, wire it up and maybe make some type of gun type trigger for coolness factor. basically you dont want to make holes for the prongs and just hold the taser in your hand, thats not cool and dangerous, plus the exlplosion will lose power as it seeps through those holes. also THE best fuel, apart from propane which is alot more work, is starter fluid, the kind from the autoparts store, not for charcol grills. when using starter fluid all the fuel you need is the shortest press of the sprayer you cn manage, then lightly blow in the camber. just a little, to help w/ the fuel air mixture. using this type of setup your spuds should go a couple hunderd yards and easily penetrate wooden fences. this is sooo cool, finally something i know about, hope this helps.
Yaa I'm starting to think that Stun Gun ignition is by far the easiest and most effective ignition system out there....
I'm also looking into spark strip ignition, but don't think it's durable enough, and pain in the ass to make..
The mixing fan as I understand it Really helps combustion. The stun gun will be wired into the gun, and won't even look like a stun gun when I'm done with it..
I'd like to keep all of the parts internal,, if I can...
Someone needs to make some aftermarket sights for these things.. I'm thinking of something like on the anti aircraft guns would be cool...
Mine is Very accurate...
I've blown the door off the kids playhouse and have knocked over the basketball hoop several times already...
As far as you building another Spud cannon,, Get at it Dude!!
Thanks for the help.
ttyle
Eric
O/ST
