Horsewright
- Oct 4, 2011
Thought I'd do a lil WIP on a pair of spur straps I made lately. Here, they are, pictured with a much older personal pair. While you might say to yourself, I'm not gonna make spur straps, the techniques involved apply to so much else in leatherwork.
This style of spur strap has several names. Buckaroo Style spur leathers, Bib Style, Two Piece style etc. We use to freehand cut this project and that was really tricky to get the parts symmetrical. So we had a set of dies built.
A left and a right bib portion and a strap. If I were to do it again I would only have one bib die done. You don't need a left and a right. You know why? Cut one out flip your leather over and cut the second out. You now have a left and a right. We'll set this up on a piece of suitable leather and then put it in the press.
This is my press. Nothing fancy, air over hydraulic. This was a Harbor Freight 20 ton press. Swapped out the jack, (I traded a knife for the air jack) and had a local welder weld on a 1/2" steel plate to provide uniform pressure over a wide enough area. The steel plate on the bottom just rests there. It's not welded to the frame like the top one.
Those are my shop heaters underneath stored there when not in use and the dumbbells and bungee cords hold down my tent when I'm grinding outside in the summer. Hold the handle and the plate lowers onto the dies pushing them through the leather.
You will hear it go "clunk" when it cuts through. Raise that plate and retrieve your parts.
So we'll need one more strap so I repeat with just the one die so that we'll have two straps and two bibs.
I'll dampen the parts and slick them and then put in the stitching groove as all four parts of the strap set will be lined and stitched.
This pair was ordered with a Carlos Border stamp and 2" diameter silver conchos. So I will do all tooling and highlighting prior to stitching in the lining, Starting on the Carlos Border stamp:
The strap parts don't have room for the Carlos stamp so I do this on these pieces. Ya have to be careful with the makers mark to make sure you do a left and a right.
So then I'll highlight the tooling with my own special concoction:
Once they are dry from the highlighting and the finish I will glue on the lining leather.
Then it's time to sew. We'll use our smaller Cobra 18, flatbed machine for this project. It produces a smaller more refined stitch than my larger machine I use for sheaths and holsters. Perfect for this application but then the smaller machine won't sew those larger projects. There is not an universal machine.
All four pieces sewn up. I'll use a fine tipped soldering iron to cut the excess threads.
Hope this lil WIP is of interest to you. I'll be finishing it off here shortly. Comments and questions are very welcome.
