- Oct 5, 2006
Spyderco Ladybug Review - Part 1
Introduction
I received a Spyderco Ladybug as part of a pass around here along with a fixed blade Aqua Salt: http://www.bladeforums.com/forums/showthread.php?t=761145. The Ladybug is a Spyderco classic design from 1990. The pass around version is the third generation Ladybug 3 Salt and comes with a yellow fiberglass reinforced nylon (FRN) handle, H1 rustproof steel, and serrated SpyderEdge. The MSRP is $49.95 and our favorite online retailers sell it for about $32.
The Ladybug is a very small knife, 4 3/8” open, with a 1 15/16” blade. At just .6 oz., it is also the lightest folding knife I’ve ever held.
Blade
The Ladybug 3‘s blade is made from H1, which I understand to be a type of ceramic. My own experience with H1 consists of about two years with a Spyderco Tasman Salt and then a Spyderco Atlantic Salt. They have seen extensive use in both fresh and salt water and I have never seen any corrosion. Both of my Salts have a plain edge along the first 10-15% of the blade, followed by 85-90% SpyderEdge serrations. The plain-edged tip is useful for detail work. The serrations have never needed sharpening, but I’ve touched up the plain-edged section and found it easier to sharpen than VG-10 or S30V. My unscientific assessment of H1 is that it doesn’t hold an edge as well as the top steels, but holds its own vs AUS 8, AUS 6, 440C, etc.
There are some reports that H1 actually hardens with use. (See the quotes from Ed Schempp posted in Reply #5 further down the thread.) The Ladybug Salt 3 came typically Spyderco sharp and I would expect similar corrosion and edge-retention performance to what I’ve experienced.
Fit & Finish
The Ladybug is made in Seki, Japan. The grind is excellent, the FRN is flawless, and the Boye dent lockback is secure with no up and down bladeplay. It has more side-to-side bladeplay, however, than I’ve ever seen in a Spyderco knife.The blade is also off-center when closed and drags along one side of the FRN. The knife is assembled with rivets, so I can’t adjust it. I suspect that a tap with a ball peen hammer would fix it, but if not, Spyderco’s legendary customer service and warranty surely would.
As might be expected on a keychain knife, the blade is very thin - almost like an Opinel. It has a little flex to it and in combination with the bladeplay, it feels like I could break it.
Introduction
Blade
Fit & Finish
